where can I get the tool for rk3229 to extract fireware and repackage it ?
    before I use tool named 'FWFactoryTool 5.0' for rk3368,rk3128. now is there a tool to extract/repackage for RK3229?
    Hi blackantt ,
    you can try Sergio Poveronys latest RK tool , but the file you want to rework must i think in the same Folder , otherwise it does not work , or
    it is only on my PC so . Give it a try , lokk for the latest , i think 5.99. .... ??? someting .
    good luck
    gefattern
      "" you can try Sergio Poveronys latest RK tool , but the file you want to rework must i think in the same Folder , otherwise it does not work , or
      any tips on how to go about it?
      interested to backup my android tv box firmware
        Hi iqong ,
        for this you can install a TWRP Recovery to your Device and back up the hole Rom .
        I think it is possible with AndroidTool too , third Tab . What kind of Box do u use ???
        good luck
        gefattern
          Hi gefattern
          I am using a generic Android TV box currently running Android ver 5.1.1
          Bought online from China
          Recently I bought another unit from the same source but the UI loaded is different. I thought of copying this old firmware to the new box as both box are identitical.
          If you could point me the link to download the tools and copy out the firmware would be very useful
          Thank you.
            Hi iqong ,
            good luck
            gefattern
            Do you know of a TWRP for RK3229 that works? I've downloaded three different builds and none work properly, none of them can properly mount all partitions, especially system. Thanks.
            iqong, yes the RK tool from Sergio Poverony is the best one to extract and build roms
            As far as dumping Roms from your box that's a bit more difficult.
              Actually it seems the only real working TWRP version for RK3229 and V88 is the one that was posted here in the forums for a different thread (flashing UT6 ROM to V88). All the ones at 4PDA simply don't work.
                Hi PaulieP ,
                did you get it , could you extract the Rom like you wanted ???
                nice Day
                gefattern
                  Originally posted by iqong View Post
                  Hi gefattern
                  Thank you.
                  Hi iqong ,
                  did you solve your Problem to get a copy of the Rom and install it to the other Box , like you wanted ???
                  have a nice Day
                  gefattern
