Beelink MINI MXIII II TV Box S905X A6 2/32GB Dual WiFi Fast Lan BT4
    Brand: Beelink
    Model: MINI MXIII II
    Type: TV Box
    System: Android 6.0
    Processor: S905X
    CPU: Amlogic S905X
    Core: 2.0GHz
    GPU: Mali-450
    RAM: 2G RAM
    RAM Type: DDR3
    ROM: 32G ROM
    Color: Black
    Decoder Format: H.264/AVC,H.265,RealVideo8/9/10
    Video format: 1080P,4K,AVI,AVS,DAT,H.265,ISO,MJPEG,MKV,MP4,MPEG, MPEG-1,MPEG-4,RM,VC-1,VP9 Profile-2,WMV
    Audio format: AAC,FLAC,MP3,OGG,RM,WMA
    Photo Format: BMP,GIF,JPEG,JPG
    Support 5.1 Surround Sound Output: No
    5G WiFi: Yes
    WIFI: 802.11 a/b/g/n/ac
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: DC Power Port,HDMI,Micro SD Card Slot,RJ45,SPDIF,USB2.0
    Language: Multi-language
    DVD Support: No
    HDMI Version: 2.0
    External Subtitle Supported: No
    System Bit: 64Bit
    Power Type: External Power Adapter Mode
    Battery Type: Remote Control Powered by 2 x AAA Battery ( Not Included )
    Product weight: 0.1780 kg
    Package weight: 0.4600 kg
    Product size (L x W x H): 9.60 x 9.60 x 1.60 cm / 3.78 x 3.78 x 0.63 inches
    Package size (L x W x H): 15.50 x 11.00 x 7.35 cm / 6.1 x 4.33 x 2.89 inches
    Package Contents: 1 x Beelink MINI MXIII IITV Box, 1 x Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x English Manual
    Gearbest
      stock remote very responsive can pointing any direction it work like airmouse
      MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
        hi. Can you give me the pros and cons of this box ? have you got libreelec running on it ?
        Have one ordered, will arrive in a few weeks.
          Hello damod11,
          Overall it is a good Box for this Price, the Firmware runs okay so far.
          For LibreElec there where some Firmware out.
          Let´s see...
          Here it is:
          Head over to there and you can run it from SD Card.
          Regards
          Neomode
            Originally posted by neomode View Post
            Hello damod11,
            Let´s see...
            Here it is:
            Regards
            Neomode
            Thanks Neomode.
            I have libreelec 8.0 on internal of T95x s905x box at the moment. Had to install in internal as the firmware was a disaster.
            Anyway the beelink is for a mate and im going to set it up for him so i just wanted to know if anyone else is running libreelec on either sd or internal.
            Good news the firmware is stable neomode, Is kodi working ok in the firmware ?
              Regards
              Neomode
              Hi, this is my second box after a RK3229, it came last week. So, LibreELEC runs from SD card without replacing Android?
              Thanks in advance.
              PS: Why Beelink market the core as 2GHz if they never pass 1.5?
                Anyone know which wifi chip is inside ?
                  open it
                    Originally posted by KAA View Post
                    open it
                    thanks for the great advice KAA but I wont have it for a few weeks.
                    I just want to check if libreelec will run on it.
                      hello
                      any news for android 7 firmware
                      or
                      update new
                      Beelink MINI MXIII-II 2
