Please help!
MK809III - How to get into flash mode after bad flash.
Originally posted by michell View PostTried a mixture of rom and kernel the stick didnt like, what should i do to get the stick into flash mode?.. When i push the reset button, it goes into Recovery system V4.2.
Please help!
then you can flash it
PS:you must install the driver before you flash.
If it does not work ,I don 't know how to fix it.Maybe you can buy a flash chip "29f64g08" replace the old one and try it again.
There are currently 1667 users online. 2 members and 1665 guests.
