X98 PRO Amlogic S912 3GB/32GB Android TV Box AC WIFI BT Gig LAN DLNA
    Click image for larger version  Name:	11.jpg Views:	1 Size:	47.0 KB ID:	649435
    Hardware Operating System: Android 6.0
    CPU: Amlogic S912 Octa core ARM Cortex-A53
    GPU: ARM Mali-T820MP3 GPU
    RAM: 3GB DDR3
    ROM: 32GB eMMC5.0
    Extended Storage: TF CARD Support 1~32GB
    Communication Wifi Connectivity: Built in 2.4G/5G Support IEEE 802.11 ab/g/n/ac
    Ethernet: 10/100M/1000M RGMII
    Bluetooth: 4.0
    Media Video Output:
    Built-in HDMI 2.0a transmitter including both controller and PHY with HDR, CEC and HDCP 2,2, 4Kx2K@60fps max resolution output
    Video Codecs:
    VP9-10 Profile-2 up to 4Kx2K@60fps
    H.265 HEVC MP-10@L5.1 up to 4Kx2K@60fps
    H.264 AVC HP@L5.1 up to 4Kx2K@30fps
    H.264 MVC up to 1080P @60fps
    MPEG-4 ASP@L5 up to 1080P@60fps (ISO-14496)
    WMV/VC-1 SP/MP/AP up to 1080P@60fps
    AVS-P16(AVS+) /AVS-P2 JiZhun Profile up to 1080P@60fps
    MPEG-2 MP/HL up to 1080P@60fps (ISO-13818)
    MPEG-1 MP/HL up to 1080P@60fps (ISO-11172)
    RealVideo 8/9/10 up to 1080P@60fps
    WebM up to VGA
    Multiple language and multiple format sub-title video support
    MJPEG and JPEG unlimited pixel resolution decoding (ISO/IEC-10918)
    Supports JPEG thumbnail, scaling, rotation and transition effects
    Supports *.mkv,*.wmv,*.mpg, *.mpeg, *.dat, *.avi, *.mov, *.iso, *.mp4, *.rm and *.jpg file
    Audio Supported:
    Audio Decoder:supports MP3 / AAC / WMA / RM / FLAC / OGG and programmable with 5.1 down-mixing
    Audio Output:HDMI/SPDIF Data Output
    Picture Supported: HD JPEG/BMP/GIF/PNG/TIFF
    Resolution: 4K2K@60FPS
    KODI: YES
    Interface 1* HDMI 2.0 output with CEC 2.0 4K*2K @ 60Hz
    2* High speed USB 2.0,support U DISK and USB HDD
    1* TF CARD Support 1~32GB
    1* SPDIF output
    1* RJ45 LAN Ethernet 10M/100M/1000M
    1* AV output
    Other Features Support DLNA, Google TV Remote, LAN, 3D Moive, Email, Office suit etc
    Power 5V/2A Power ON :blue; Standby :Red
    Package Contents 1 x TV box
    1 x IR remote
    1 x HDMI cable
    1 x Power adapter (A right AC Adapter will be sent as your shipping country)
    1 x User manual
    Click image for larger versionName:	22.jpgViews:	1Size:	105.0 KBID:	649433
    Click image for larger versionName:	33.jpgViews:	1Size:	127.5 KBID:	649434
    Geekbuying
    Today we get a chance to look at the X98 PRO Amlogic S912 3GB/32GB Android TV Box AC WIFI BT Gig LAN DLNA
    RAM: 3GB DDR3
    ROM: 32GB eMMC5.0
    I like boot up sequences if they look groovy, well I think it does.
    Geekbuying
      Geekbuying
        Geekbuying
          Looking ok
          Good looking unit simple design using case for HEAT Sink good idea.
          Unit Does have Root, but no Upper or lower Task bars at this stage.
          Also running Android 6 dated December 2016 no OTA update found as yet, may Android 7 may arrive
          Has the usual Web software etc, more info coming. some Junk in the Trunk.
            Lets have a look around and what we have and a few test looking good for a S912
            Good looking Benchmarks to be seen DDR3 ram, Temps not to bad when pushed WiFi and Ethernet Speeds Good here, Good looking unit.
            Kodi 16.1 is installed, usual addons that dont mean much now.
            Lets hope for Android 7 be a good unit indeed.
            Geekbuying
