http://chinagadgetsreviews.com/downl...us-tv-box.html
M92S is sufficiently similar to the T95kPro The rom seems to be working very smoothly but with the following issues:
1)The front LCD clock on the box is not working
2)There is no way to configure the home screen (generic mbox launcher) besides adding apps to the bottom row. Use another launcher such as Nova, Google, etc
3) TWRP will not install via Flashify - works on Superceleron's rom), but not with this rom... When you reboot into recovery, you get nada!
4) Has superuser installed instead of SuperSU - could not get adaway to work..ugh
.gif)
5) comes with kodi 17.2 installed and some basic addons - update to 17.3, but the preinstalled sports repo causes it to crash on exit.
6) mobdro, showbox,tc are installed, but out of date.
7) google services need to be updated when you install google playstore apps, but DOES NOT CRASH! thereafter
8) Magisk does not work.
9) stock browser takes you to this china box site by default with more links to kodi addons,etc
10) must manually set time zone to get proper time
11) ASOP keyboard does not play well with my logitech k400 - install another off google play.
12) had to adjust screen zoom after install manually.
If someone could fix the front clock, add supersu, add twrp, magisk, and maybe viper audio+dolby, this would be a sweet rom! works very well for what it is given that is a stock rom for another box.
.gif)
