Sixaxis app
    Sixaxis app
    hi guys,
    I was trying to get the sixaxis app to work on my CX-919 with finless 4.2.2 rom. Unfortunately however I can not pair my stick with the controller. Is this a known issue? Does the bluetooth somehow not work?
    I can however see my stick on my GS3 when i activate bluetooth.
    Has somebody got it working? Any kind of input would be highly appreciated!
    Btw. i matched the master adress first and that worked without issue.
    Originally posted by finrodize View Post
    hi guys,
    Try this. First go to six-axis and make sure the bluetooth address reported in the bottom left is the same as in settings>about>status. If it's not, uninstall/reinstall or clear app's data.
    Connect your PS3 controller via cable to the device and choose set master address. Try both USB ports if one doesn't work.
    Press the start button in six-axis. Make sure six-axis has root.
    DISCONNECT the USB cable.
    Press the PS button on the controller.
    It should work. It does not work on some inauthentic controller models.
    The biggest issue I had with this app was when using TiBu to restore it, the master address would not update to the new address after a wipe.
    Good luck,
      Good luck,
      Ok, I'll check that with settings>about>status.
      What ever do you mean by trying both ports? I set the master adress from my computer and not my android stick. :S And my stick only has 1 usb port and 2 additional micro usb.
      The controller is the original one from when i bought my PS3 directly after its launch (in switzerland). So I'm quite certain it's the original
      Thanks for your feedback!
        AW: Sixaxis app
        After anothrr go at it it works now. However for some reason i can not use my usb airmouse anymore now. Is there any way to fix this? Its like device doesn't recognice the mouse anymore.. :/
          AW: Sixaxis app
          Reflashing seems to be the solution currently..
          If anyone has a clue where the problem lies, i would still be very grateful!
