GT1 Ultimate Bricked
Originally posted by messerchmidtyou need to get someone to solder in a new reset button, and then do the recovery with a full flash, including bootloader erase
About the bootloader erase, SC says not to erase bootloader. So should I flash the stock rom and then again try SC rom?
Originally posted by VideoNJ View Post
You don't need the reset button for the sdcard method..
Hi, thanks for that. But I can't get to recovery mode, so this doesn't work for me. Also the stock firmware for my device doesnt have uboot.bin file.
Just try it without the uboot.bin...
Edit: Please correct me someone with more knowledge than i have... Iam also interested how exactly this works with a bricked box... You never know..
Edit2: You can probably use the uboot.bin of another Rom that runs on your Box.Last edited by jit18; 06 June 2017, 18:02.
I don't want to be a smartass but if i understand the method right the recovery starts from the sdcard (recovery.img) and you only need the uboot.bin if your bootloader is dead...
Will try to look for uboot.bin from some other amlogic S912 rom, but not very hopeful that it will work.
Ok, now I am able to use the USB cable method to connect to burning tool. It recognizes the device, but then gets stuck at 4% downloading uboot. The error screen is attached (I tried it thrice, with same result). Not sure what this is about and what can I do now?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Ok, I somehow managed to get to burning successfully message in burning tool (by connecting power). But still the box is not starting up. And now after disconnecting power, it is again not being recognized in windows. So back to square one, right after I thought the nightmare was over
Edit: Ok, it has started now, with stock firmware. Thanks a lot guys for all the help. I did short the pins as shown by Jhonnie in another thread, so that may have helped. Phew! Now will try to install SC rom. Thanks all of you amazing people at freaktab!
Originally posted by jit18Your Box has probably a different WiFi chip then the one supported by SC Rom
I seem to have messed up the wifi while trying to restore the bootloader or something. Is there a way for me to find out what may be wrong. I read somewhere that the mac key could be messed up, but have no idea how to check that.
Edit: Suddenly, the next day wifi starts connecting on its own! Guess its my lucky day.
Originally posted by VideoNJ View PostOk, I somehow managed to get to burning successfully message in burning tool (by connecting power). But still the box is not starting up. And now after disconnecting power, it is again not being recognized in windows. So back to square one, right after I thought the nightmare was over
I tried plugging the power adapter too while doing it, but still no luck going past these 4% and stuck on Uboot download
Any additional information on that part would be great !
Fred
There are currently 2097 users online. 0 members and 2097 guests.
