What Model is this Tablet (PR548797) and does it support 3G Stick / Hostmode ?
Now I try to find Informations about the conectivity if the device can use a 3G Stick. But I can't find this product in any comunity boards. Can you give me a hint where to search ?
I did a quick search, but have only come up with this website that seems to deal with Polaroid Tablets in Europe, http://www.mms-support.net/ you might try going to the site and maybe asking them...
I did look on the website for your tablet but it was not shown. however they may not of updated their website yet
I believe Polaroid in the EU is a different company than Polaroid in the U.S.A.- different devices. Our tablets support host mode, as far as I've seen, and support for various USB devices is in the kernel. Older devices will be more likely to be supported, hit or miss. If other similar tablets work with that 3g stick you may be in luck. You might run cpu-z on that tab for more info.
