Hystou FMP03 Barebone System Core i5-4200 Mini PC WIFI Gig LAN HDMI SATA VGA Fanless
    Hystou FMP03 Barebone System Core™ i3-4010U / i5-4200u / i3-5005U 4G/64G/128G 4K Mini PC
    • Intel Core i5-4200U, an ultra low voltage dual-core processor for ultrabooks, is based on the Haswell architecture and is manufactured in 22nm. Due to Hyper-Threading, the two cores can handle up to four threads in parallel, leading to better utilization of the CPU. Each core offers a base speed of 1.6 GHz, but can dynamically increase clock rates with Turbo Boost up to 2.6 GHz for 1 active core or 2.3 GHz for 2 active cores.
    • Intel Core i3-4010U ,an ULV (ultra low voltage) dual core processor for ultrabook, is based on the Haswell architecture and is manufactured in 22nm. Due to Hyper-Treading, the two cores can handle up to 4 threads in parallel, leading to better utilization of the CPU. Each core offers a base speed of 1.7 GHz and includes no Turbo Boost support.
    • Intel Core i3-5005U, an ULV (ultra low voltage) dual-core processor based on the Broadwell architecture, is composed of two CPU cores with Hyper-Threading clocked at 2.0 GHz (no Turbo), integrating an HD Graphics 5500 GPU and a dual-channel DDR3(L)-1600 memory controller. The Core i3 is manufactured in a 14 nm process with FinFET transistors.
    All Support the Following
    DDR3 4GB RAM, 64GB SSD, Both Extendable
    DDR3 4GB RAM, 128GB SSD, Both Extendable
    • It boasts DDR3 4GB RAM, 64GB / 128 GB SSD, advantageous in performance, security and reliability, ascribing to the eMMC memory, ultimately delivering a richer end-user experience.
    • ROM can be extended to 16GB, RAM 512GB, customers may contact our customer service for specific requirements.
    Gigabit LAN
    • Gigabit LAN provides a data rate of 1 billion bits per second.
    Supports 802.11 b/g/n
    • Supports 802.11 b/g/n wireless standard, among which 802.11b has a maximum bandwidth of 11 Mbps, 802.11g 54 Mbps and 802.11n 150 Mbps.
    mSATA and SATA
    • Onboard mSATA and SATA port supporting SSD+HDD dual storage.
    Applications
    • Office Work: Office, skype, yahoo, outlook and all other office requirement support and runs perfectly.
    • Design Work: Photoshop, CoreLDRAW, Dreamweaver, ILLustrator, Flash, Indesign and others.
    • Game Playing: Support most of the online games and PC games, like Warcraft, Counter-Strike (CS), support 3D games.
    • Entertainment: Support 4k video play, XBMC and others.
    Click image for larger version  Name:	2016051716595961f90m3.jpg Views:	1 Size:	20.7 KB ID:	572859
    Click image for larger version  Name:	20160517170002lrwd8xy.jpg Views:	1 Size:	33.8 KB ID:	572848
    HYSTOU FMP03 Fanless Mini PC - CORE-I5-4200U
    Click image for larger version  Name:	1473760153919490.jpg Views:	1 Size:	254.0 KB ID:	645693
    Main Features:
    ● Processor chipset: Intel HM86 Express.
    ● Sealed construction with fanless operation.
    ● Support Intel core i5 and maximum speed can be up to 2.6GHz.
    ● Support Giga LAN, 4 USB 3.0 and 2 USB 2.0 ports.
    ● Onboard 2 DDR3L memory slot support up to 16GB RAM.
    ● Onboard mSATA and SATA port support SSD + HDD dual storage.
    ● Low power 12V power supply.
    ● Support Windows 7, 8, 10 and all kind of Linux OS.
    Click image for larger version  Name:	1473760153206841.jpg Views:	1 Size:	176.6 KB ID:	645692
    Click image for larger version  Name:	1473760154707370.jpg Views:	1 Size:	212.1 KB ID:	645694
    Bare Bones Unit Need own Hardware and Software
    Gearbest
      looks nice, it will be good for a compile pc... this is for me of course!
        Today we have a chance to have a bit of a look see at the
        Bare Bones System no Ram or hdd/sdd or Software, waiting for a few bits in the mail and it will be up and running soon.
        Usual Big Box
        Whats In the Box
        Usual Guided Tour around the Hystou
        Peek Inside
        Standing in all its glory
        All Solid Alloy, Plenty of Ports,
        Neat, sweet and dare I say petite compact unit for sure
        More to Come as I build this one up
        Gearbest
          I got mine today and im going to use it as my compile pc with linux, in this case ubuntu
          I think its a great buy if you want a build pc or a work pc, for linux or windows!
          You guys can buy it at gearbest , here is the direct link -> HYSTOU FMP03 Fanless Mini PC - CORE-I5-4250U
          I will post some pics now, later i will make a video after i set it up compiling FTMC
          Sorry the quality of the pics, it my mobile and its camera its not that great!
          Click image for larger version  Name:	IMG_20170606_215957.jpg Views:	2 Size:	118.0 KB ID:	650558
          Click image for larger version  Name:	IMG_20170606_220015.jpg Views:	1 Size:	129.7 KB ID:	650554
          Click image for larger version  Name:	IMG_20170606_220249.jpg Views:	1 Size:	117.5 KB ID:	650555
          Click image for larger version  Name:	IMG_20170606_220418.jpg Views:	1 Size:	114.4 KB ID:	650553
          Click image for larger version  Name:	IMG_20170606_220430.jpg Views:	1 Size:	138.5 KB ID:	650552
          Click image for larger version  Name:	IMG_20170606_220502.jpg Views:	1 Size:	119.4 KB ID:	650551
          Click image for larger version  Name:	IMG_20170606_220850.jpg Views:	1 Size:	145.0 KB ID:	650557
          Click image for larger version  Name:	IMG_20170606_221557.jpg Views:	1 Size:	181.6 KB ID:	650559
          Click image for larger version  Name:	IMG_20170606_221614.jpg Views:	1 Size:	178.6 KB ID:	650560
          Click image for larger version  Name:	IMG_20170606_222852.jpg Views:	1 Size:	132.2 KB ID:	650564
          Click image for larger version  Name:	IMG_20170606_223030.jpg Views:	1 Size:	114.1 KB ID:	650565
          Click image for larger version  Name:	IMG_20170606_223503.jpg Views:	1 Size:	94.0 KB ID:	650561
          Click image for larger version  Name:	IMG_20170606_223517.jpg Views:	1 Size:	99.0 KB ID:	650563
          Click image for larger version  Name:	IMG_20170606_223545.jpg Views:	1 Size:	109.6 KB ID:	650562
          Further Discussion: Click Here > Freaktab
