Mini M8S PRO Amlogic 912 android 6 3/32GB Dual WiFi, Gig LAn BT4
    Model: Mini M8S PRO
    Type: TV Box
    System: Android 6.0
    Processor: Amlogic S912
    CPU: Cortex A53
    Core: Octa Core
    GPU: ARM Mali-T820MP3
    RAM: 3GB
    RAM Type: DDR4
    ROM: 32G
    Max. Extended Capacity: 32G
    TV Box Features: 5G WiFi
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: 4K,AVI,DAT,ISO,MKV,MP4,MPEG,RM,WMV
    Audio format: AAC,DTS,FLAC,MP3,OGG,RM,TrueHD,WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: Yes
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: DC Power Port,HDMI,RJ45,SPDIF,TF card,USB2.0
    Antenna: Yes
    Camera: Without
    Language: Multi-language
    DVD Support: No
    HDMI Version: 2.0
    Other Functions: DLNA,ISO Files,Miracast
    External Subtitle Supported: Yes
    HDMI Function: CEC
    Power Comsumption: 6W
    RJ45 Port Speed: 1000M
    System Bit: 64Bit
    WiFi Chip: 9377
    Power Type: External Power Adapter Mode
    Product weight: 0.0900 kg
    Package weight: 0.1200 kg
    Product size (L x W x H): 11.00 x 11.00 x 1.75 cm / 4.33 x 4.33 x 0.69 inches
    Package size (L x W x H): 16.00 x 16.00 x 4.00 cm / 6.3 x 6.3 x 1.57 inches
    Package Contents: 1 x Mini M8S PRO TV Box, 1 x Power Adapter, 1 x Remote Control, 1 x HDMI Cable
ID:	642457Click image for larger version
    Gearbest
    Today we can have a look at the Mini M8S PRO Amlogic 912 android 6 3/32GB Dual WiFi, Gig Lan BT4
    Simple looking unit not a lot of Ventilation going on
    Amlogic 912 3/32Gb of Ram
      A few bench tests a bit of information
      I do like the UI a Windows feel and quick short cuts on home screen to get to some hardware setting, WiFi, BT, Sound etc.
      Performance looks ok Surprised runs pretty cool considering no vents must be that hunk of metal and thermal pad working well and not tin lids keeping the heat in.
      Box performs well and do like what I am seeing WiFi and ether net speeds Ok and as test below show not to bad Performance wise.
      had an update as soon as unit was powered up so all went well.
      Unit was installed with Qodi, not any more...and not much other Junk
      Installed an Older Netflix V4 working ok at present and the Unit does have Root
      You can see what's going on with screen caps below. and a bit of a video at the end of the UI and Boot
      A quick Video of the UI and boot and an attempt to boot like Windows
      Gearbest
      Discussion can be Found
