When flashing new software, I've also had my stick powered by USB (although it is through the back microUSB OTG port rather than the side microUSB power port) and have run across no issues while updating apps etc. I'm wondering what processes necessitate this stick needing 2A of power (which in reality is what large power hungry tablets like the IPad use to power/recharge and run IPS or retina screens)? Why would this stick which has no screen and no rechargeable battery need 2A of power to function?
Personally, I've noted whole OS reboots/crashes regardless of whether I was on the stock firmware or the new Finless ROM (albeit much less with the Finless ROM). I'm thinking that the stock charger doesn't do such a great job of regulating power which may be why I'm seeing crashes. With USB, power should/may be regulated much better than with the stock charger which would equate to better overall stability.
Also, if using only USB power, the stick should not get nearly as warm since it's not pulling 2A of power. Can anyone else verify if they are using USB alone to power their CX-919 and what their experience is?
smithmal
