Elephone P8 Mini 4G Smartphone MTK6750T Octa Core 1.5GHz 4/64GB 802.11a/b/g/n WiFi
    Click image for larger version  Name:	20170517144738_67083.jpg Views:	1 Size:	150.1 KB ID:	651418
    Wireless Connectivity: 3G,4G,Bluetooth 4.0,GPS,GSM,WiFi
    WIFI: 802.11a/b/g/n wireless internet
    Network type: FDD-LTE,GSM,TDD-LTE,WCDMA
    2G: GSM 1800MHz,GSM 1900MHz,GSM 850MHz,GSM 900MHz
    3G: WCDMA B1 2100MHz,WCDMA B20 800MHz,WCDMA B8 900MHz
    4G LTE: FDD B1 2100MHz,FDD B20 800MHz,FDD B3 1800MHz,FDD B5 850MHz,FDD B7 2600MHz,TDD B38 2600MHz,TDD B40 2300MHz,TDD B41 2500MHz
    133G Weight, matte texture back cover Streamlined unibody and matte texture back, feels more comfortable in hand. and 5.0" display,
    5.0 inch Sharp FHD screen, P8mini's color performance is comparable with AMOLED screen.
    95% NTSC,wide color gamut, 1080P FHD Resolution
    Super-fast fingerprint sensor
    The fingerprint sensor of P8 mini is set at the back of the body, which is
    easy for using with one hand, one action can wake up your
    screen and unlock your phone at the same time. .
    Dual SIM card, free switching
    P8mini has hybrid card slot. You can choose two SIM cards or one
    SIM card and one micro card, which is expandable up to 128GB.
    Gearbest
    Lets have a bit of a close look at the Elephone P8 Mini...
    Gearbest
      Some Benchmarks to see how it performs.....
      Click image for larger version  Name:	1.jpg Views:	1 Size:	78.8 KB ID:	651435
      Click image for larger version  Name:	2.jpg Views:	1 Size:	75.1 KB ID:	651436
      Gearbest
        A quick Photo Sample Using Phone Camera and my normal camera.
          Had a good play of this phone (still no sim) long story wont bore you.
          Have enable finger print scanner for quick switch on and works well give a touch move the finger around done.
          Have not switched the unit off since day one, WiFi always connected, email being pushed and a bit of music the the BT speaker,
          A Few hours of Netflix here and there set up cast to the TV..and happening OK
          4 days and power is down to about 10~20% with all my fiddling and use
          I find Sound is a little tinny for my ears ( that could be a age thing) from the speaker and I find Notification a just a little low.
          Remember it is a phone first all else is a bonus/option
          Running Android 7 a clean rom is good rom as mentioned. No Junk in the Trunk for the price has to be a bargain i feel
          More to come as it happens
            Found The FM radio very simple UI but does the job well if FM radio is your cup of Tea
            Also had a fiddle with the cast option to TV also works very well.
            Gearbest
