Khadas Releases New Nougat ROM For The Vim...
    From the Khadas forum.
    "ROM Infos:
    • ROM version: Vim_Nougat_Root_170612.7z
    • MD5SUM: 2016d6fa96664e931dd1b0feb0d9d024
    • The ROM is for EMMC installation only
    Change Log
    • Enable I2S bus(PIN29/30/31/32) as default
    • Fixup the issue of 4k video playing not smooth
    • Setup logo
    • Add the support for IR mouse mode
    • Update the GAPPS"
    Looking ok In and Installed...temp running low 30's idle
    Thanks for the Heads up
      Good to hear it is keeping it's cool.
