Advertised Specs:
- Processor: Intel Cherry Trail Z8300 Quad-core, up to 1.84GHz.
- GPU: Intel Gen 8-LP.
- Dual OS Windows 10 and Android 5.1
- 4GB LPDDR3 + 64GB eMMC, 64GB maximum extended capacity. Also available with 2GB/32GB configuration.
- Bluetooth V4.0 connectivity: Easy pairing with most Bluetooth-enabled devices
- Dual-band WiFi(2.4GHz / 5GHz) - standard: IEEE 802.11b / g / n / ac.
- HDMI 1.4A connector
- One USB 3.0 port, three USB 2.0 host ports and one micro USB 2.0 port.
- Micro SD card slot.
- Battery: Rechargeable 2600mAh lithium-ion battery.
- Charging time 2-3 hours=2 hours of continuous playback, 4 hours standby time.
- Display: 5 inch 720 x 1280
- Touch panel: G + P, 5 points touch, easy to operate.
- Support wire and wireless keyboard and mouse, flash 11, HTML 5, browser, video 1080P output,
decoding 4K video
- Power Adapter 5V 3A, Power Adapter available for US plug and EU plug.
- Product size (L x W x H): 13.50 x 9.00 x 2.00 cm / 5.31 x 3.54 x 0.79 inches
- Package Contents: 1 x GOLE1 5 inch Mini PC, 1 x HDMI Cable, 1 x Power Adapter, 1 x Printed English Manual*
* A PDF User's Manual is also available.
Some stock images....
The GOLE1 textured retail box was packed well inside a tight-fitting, heavy-gauge cardboard outer box with GOLE branding. All arrived in good condition. I would like to thank Gearbest for generously providing the GOLE1. A tip of the hat to DHL for getting it here quickly and in good shape.
Outer Box..
GOLE has gone with a "simple elegance" type of style for the retail packaging. No references to any of the things that might draw interest from Customs, such as Kodi, XBMC or WIndows logos. A classy look, nice kit.
The box contents are well-fitted and protected from the rigors of the long trip. Individual packages for the HDMI cable and Power Adapter. Unseen is the padded Box top.
Some views...
A look inside, but just a peek, not going to become more intimate with it at the moment...
Seen are the AP6234 WiFi module w/snap on IPEX coax antenna connector. Also seen the 2600mAh battery(if my math is correct) and the mechanically retained heatsink. Also note the ventilation holes covered with screen to keep the bugs and FOD out....a nice touch.
Here we see the weight of the GOLE1. First image shows the scale weighing a US Nickel. US Nickels weigh 5grms, image shows the scale is reasonably accurate.
The GOLE1 Mini PC is somewhat unique among the crowd. A 5 inch IPS touch panel display and a battery allow for a completely self-contained, portable, Dual-OS Mini PC.
A full compliment of ports/jacks, a micro SD card slot and an external antenna, round out the features.
Just getting a feel for this neat little device, more coming soon.
Gearbest offers the GOLE1 in two configurations, 2GB/32GB** and 4GB/64GB**. Power Adapters are available for both EU and US receptacles(plugs).
**(RAM/Storage)
GOLE1 Indiegogo
GOLE Technology
See more on the GOLE1 Intel Mini PC here.
