Model: TX95 - X1 Type: TV Box System: Android 6.0 CPU: Amlogic S905X Core: Quad Core GPU: Mali-450 RAM: 1G RAM Type: DDR3 ROM: 16G Max. Extended Capacity: 128G |
Decoder Format: H.264,H.265 Video format: 1080P,4K,4K x 2K,H.264,H.265,MP4 Audio format: AAC,DTS,FLAC,M4A,MP3,OGG,RM,WAV,WMA Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes Bluetooth: Bluetooth4.0 Power Supply: Charge Adapter Interface: DC Power Port,HDMI,RJ45,SPDIF,TF card,USB2.0 Antenna: No Language: Multi-language DVD Support: No HDMI Version: 2.0 External Subtitle Supported: Yes Power Comsumption: 10W RJ45 Port Speed: 10 / 100Mbps |
System Bit: 64Bit WiFi Chip: QUALCOMM 9377 |
Power Type: External Power Adapter Mode |
Remote Controller Battery: 2 x AAA batteries ( not included ) |
Product weight: 0.1710 kg Package weight: 0.6200 kg Product size (L x W x H): 10.30 x 10.30 x 2.30 cm / 4.06 x 4.06 x 0.91 inches Package size (L x W x H): 19.50 x 11.50 x 6.50 cm / 7.68 x 4.53 x 2.56 inches |
Package Contents: 1 x TX95 - X1 TV Box, 1 x Power Adapter |
Gearbest
