General | Model: R-TV BOX Pro |
Hardware & OS | CPU: Amlogic S912 64 bit Octa core ARM Cortex-A53 CPU GPU: ARM Mali-T820MP3 GPU SDRAM: 3GB DDR4 FLASH: 32GB eMMC OS: Android 7.1 |
Communication | WiFi: 2.4GHZ/5.8GHZ 802.11a/b/g/n AP6330 LAN Ethernet: 10/100M/1000M |
Media | Video decorder: H.265 4K @60fps 10btis, VP9 Profile 2, H.264 4K @30fps, AVS+ 1080P @60fps Video encorder: H.264 1080P @60fps HDR: HDR 10, HLG HDR KODI: KODI 17.1 DRM: Optional; Microsoft Playready,Verimatrix, Google Widevine Level1 Supported: Google Widevine Level3 Decoder format: HD MPEG1/2/4,H.265/HEVC, HD AVC/VC-1,RM/RMVB,Xvid/DivX3/4/5/6 ,RealVideo8/9/10 Media format: Avi/Rm/Rmvb/Ts/Vob/Mkv/Mov/ISO/wmv/asf/flv/dat/mpg/mpeg Music format: MP3/WMA/AAC/WAV/OGG/DDP/TrueHD/HD/FLAC/APE Photo format: HD JPEG/BMP/GIF/PNG/TIFF Network Function: Miracast,Airplay,Skype chatting,Picasa,Youtube,Flicker,Facebook,Online movies,etc. |
Interface | 1*HDMI 2.0 4*USB host 1*SPDIF 1*AV 1*Micro SD card (TF card) reader 1*RJ45 LAN Port 1*DC in |
Other Features | Supports DLNA, Google TV Remote, LAN, 3D Moive, Email, Office suit etc. Power: DC 5V/2A Power ON :blue; Standby :Red |
Package Contents | 1 x TV box 1 x IR remote 1 x HDMI cable 1 x Power adapter (A right AC Adapter will be sent as your shipping country) 1 x User manual |
R-TV BOX Pro Android 7.1 S912 3GB/ DDR4 32GB eMMC Dual WIFI BT Gig Lan.
GeekbuyingLast edited by trebor; 16 June 2017, 10:49.Tags: None
I have contacted Geekbuying on firmware update on a few times and each time the answer is it will be posted in few days but no progress so far.
I have the 3GB/16GB version and it has been pretty smooth so far so overall I am satisfied with it, Hope it has a firnware update as some apps are sluggish occasionally.
Suggest you later don't buy the TV box of the company, the shenzhen company in China in order to reduce the quality of your to their complaints, they change on hardware encryption PCB that they cannot use the ota upgrade. You can't root and enter recovery mode. Only one firmware is used to hang the box. Advice from a Chinese player who is deeply hurt.The company changed the PCB of the TV box after National Day last year. It can't be upgraded.
There are currently 3311 users online. 0 members and 3311 guests.
