Elephone P8 Mini 4G Smartphone MTK6750T Octa Core 1.5GHz 4/64GB 802.11a/b/g/n WiFi
    Wireless Connectivity: 3G,4G,Bluetooth 4.0,GPS,GSM,WiFi
    WIFI: 802.11a/b/g/n wireless internet
    Network type: FDD-LTE,GSM,TDD-LTE,WCDMA
    2G: GSM 1800MHz,GSM 1900MHz,GSM 850MHz,GSM 900MHz
    3G: WCDMA B1 2100MHz,WCDMA B20 800MHz,WCDMA B8 900MHz
    4G LTE: FDD B1 2100MHz,FDD B20 800MHz,FDD B3 1800MHz,FDD B5 850MHz,FDD B7 2600MHz,TDD B38 2600MHz,TDD B40 2300MHz,TDD B41 2500MHz
    133G Weight, matte texture back cover Streamlined unibody and matte texture back, feels more comfortable in hand. and 5.0" display,
    5.0 inch Sharp FHD screen, P8mini's color performance is comparable with AMOLED screen.
    95% NTSC,wide color gamut, 1080P FHD Resolution
    Super-fast fingerprint sensor
    The fingerprint sensor of P8 mini is set at the back of the body, which is
    easy for using with one hand, one action can wake up your
    screen and unlock your phone at the same time. .
    Dual SIM card, free switching
    P8mini has hybrid card slot. You can choose two SIM cards or one
    SIM card and one micro card, which is expandable up to 128GB.
    Gearbest
    Lets have a bit of a close look at the Elephone P8 Mini...
      Some Benchmarks to see how it performs.....click for larger image
      Click image for larger versionName:	zXQ4P3j.gifViews:	1Size:	317.5 KBID:	659454Click image for larger version  Name:	bXxIDTs.jpg Views:	1 Size:	145.2 KB ID:	659453Click image for larger version  Name:	2.jpg Views:	1 Size:	75.1 KB ID:	651436Click image for larger versionName:	DURQnga.gifViews:	1Size:	116.4 KBID:	659452Click image for larger version  Name:	ZHNEu0o.jpg Views:	1 Size:	29.7 KB ID:	659451Click image for larger version  Name:	1.jpg Views:	1 Size:	78.8 KB ID:	651435
        A quick Photo Sample Using Phone Camera and my normal camera.
          Had a good play of this phone (still no sim) long story wont bore you.
          Have enable finger print scanner for quick switch on and works well give a touch move the finger around done.
          Have not switched the unit off since day one, WiFi always connected, email being pushed and a bit of music the the BT speaker,
          A Few hours of Netflix here and there set up cast to the TV..and happening OK
          4 days and power is down to about 10~20% with all my fiddling and use
          I find Sound is a little tinny for my ears ( that could be a age thing) from the speaker and I find Notification a just a little low.
          Remember it is a phone first all else is a bonus/option
          Running Android 7 a clean rom is good rom as mentioned. No Junk in the Trunk for the price has to be a bargain i feel
          More to come as it happens
            Found The FM radio very simple UI but does the job well if FM radio is your cup of Tea
            Click image for larger versionName:	fm.jpgViews:	1Size:	22.1 KBID:	652088
            Also had a fiddle with the Cast option to TV also works very well.
            Click image for larger versionName:	cast.jpgViews:	1Size:	78.8 KBID:	652089
              Been a good month with Elephone P8 Mini....
              As my first Phone from the other side of the equator direct I am impressed.
              Performance on our local 4G service is good (yes finally got the Sim)
              Having no issues, just need to find a case...
              Running A7 and No Junk is good.
              I have setup fingerprint scanner on rear so easy login etc also gesture, easy to use.
              Use it a lot on wifi at home for internet and the usual browsing around..no issues here.
              Very thin and light to handle often have to check my pockets if I have it after using by Bulky S3.
              Thanks Gearbest for the opportunity to Test and review and use as my daily device
                Here we are 12 month later and the P8 Mini still doing well
                No updates since day one, but it is a phone.
                Daily use, easy to use
                  Well said it before and since its 12 months I will say it again
                  Here we are 12 month later and the P8 Mini is still doing well
                  No updates since day one, but it is a phone and works
                  Well had one update a new back Cover
