GPD Pocket 7 Inch Tablet PC Licensed Windows10 Intel Atom Z8750 8GB RAM
    Highlight
    Fits Into Your Pocket
    As the name suggests, GPD Pocket is a nifty tablet meant to fit in your pocket so that you can carry any important file wherever you want. Or you can carry your weapon in your pocket as you can also run Linux on it…good to go for hackers!
    Windows or Ubuntu-Driven UMPC with Massive Storage
    A pure UMPC (no gaming controls) contemplated in the second half of 2016, GPD Pocket is put together with the most impressive specs. Aside from the known 4GB RAM and 128GB flash storage, it is expected to be running on either Windows 10, or Ubuntu 16.04 LTS.
    Performance-Oriented CPU
    To summarize the GPD Pocket, it is powered by the top model of the latest Intel Atom 14nm stack. A quad-core processor, Atom x7-Z8750 features a base frequency of 1.6 GHz, a turbo frequency climbing up to a maximum of 2.56 GHz, and all of which is done within a 2 watt Scenario Design Power.
    Exquisite IPS Touch Display
    GPD isn`t new to the market, and prior to Pocket, the GPD Win highlighted to GPD that some handheld game players are also the fans of PC games. An iconic 7 Inch Tablet with Gorilla Glass Touch Screen has thus come into being, offering a laptop which can be put into the pocket.
    Noticeably, the thin bezel enclosed the display keeps the overall size of the gadget to a minimum. Barely an inch of touch-pad can be found, but a Thinkpad-style pointing stick instead. This, Again will minimize the overall size of the device.
    1920*1080P FHD Resolution
    Touting a 1920*1080 resolution, Pocket pixel density rocketed a record-setting 314.7 PPI, knocking out the Retina Display defined by Apple. In other words, with so many pixels packed closely together, a single pixel can hardly be recognized by bare eyes when the device stays a foot away.
    Chiclet Style Qwerty Keyboard
    The overall dimensions of the device indicates that you get no chance to hammer away on a full-sized keyboard, but a chiclet style Qwerty one dotted with a trackball, exclusively serviceable for tweets, forum posts or some basic web browsing.
    Two-pronged Scheme on Heat Dissipation
    As we know, the original passive cooling scheme was abandoned in GPD Win to make way for internal Ball Bearing Fan - active cooling scheme. However, this is no longer the case in GPD Pocket which applies both the copper tube to conduct heat and the fan to dissipate it.
    Located right under the copper tube welding spot is the CPU that conducts heat to the copper tube. Heat dissipates from the copper tube air outlet when the fan blows. So what really rocks in this scheme except for dust-proof performance? That`s it - Heat Rejection !
    Multi-Port & 7000mAh Battery
    As can be seen from the images released by GPD, the Pocket will be studded with USB Type-C, USB- A (USB3.0), mini HDMI, earphone jack and a micro SD slot for an extra 128GB storage extension. The mini PC will also sport a 7000mAh battery to provide a good-enough battery.
    eneral Brand: GPD
    Model: Pocket
    Type: UMPC
    Operating System:Windows 10 Home
    Processor CPU: Intel Atom x7-Z8750
    Core: Quad core
    Base Frequency: 1.6GHz
    Burst Frequency: 2.56Ghz
    L1 Cache: 32KB x 2
    L2 Cache: 2MB
    Manufacturing Process: 14mm
    Instruction Set: 6bit
    Storage RAM: 8GB LPDDR3-1600
    ROM: 128GB eMMc
    Display Touch Panel: Capacitive panel,multi-touch support
    Display: 16:10
    Resolution: 1920*1200
    Pixels Per Inch(PPI): 323.45 PPI
    Screen: Corning Gorilla Glass 3
    Graphics card Graphics: Intel HD Graphics
    Craphics Base frequency: 200MHz
    Craphics Burst frequency: 600MHz
    Execution unit: 16
    Multimedia Audio System: Realtek ALC5645
    Loudspeaker: Built-in stereo speaker
    MIC: Support
    Communication Wireless:802.11a/ac/b/g/n Wlan,2.4/5GHz Dual-band
    Bluetooth:4.1
    Interfaces I/O: 1x USB Type-C 3.0,1x USB Type-A 3.0
    Video Interface: HDMI D Type
    Audio interface: 3.5mm Headset jack
    Input device QWERTY,TrackPoint
    Battery Battery: 7000mAh Non-removeable Li-Po battery
    Battery Life: About 12 hours(It should depended on the actual working condition)
    Appearance Shell Material: CNC Craft,Magnesium alloy
    Sensor: Gravity Sensor,Hall sensor
    Weight: 480g
    Media Audio format:Mp3/Mp4/Wma/Ogg/Amr/Aac/Flac/Ape/Wav/MidI/Ra
    Video format:Mp4/Ape/Wmv/Rm/Rmvb/Asf/Avi/Mov
    Picture format:Jpg/Png/Gif/Bmp/Jpeg/Webp/Wbmp
    Package GPD Pocket x 1
    5V/2.5A Charger x 1
    Warranty Card x 1
    Manual x 1
    Gearbest
