Oukitel k6000 Pro
    Oukitel k6000 Pro
    Today we received this message from our mobile company
    Important: The Optus 2G mobile network will be turned off from 1 August 2017. Our records indicate your 3G single-band phone may not work after this date. Upgrade to a new phone to stay connected to the Optus mobile network. Prepaid phones start from just $39. To see our range of prepaid phones go to optus.com.au/prepaidphones or visit any Yes Optus store. For more info go to optus.com.au/2g or call 1800502057. Unsub: optus.com.au/unsub
    Please suggest if we can use this phone going forward.
    Sent from my K6000 Plus using Tapatalk
    Hello,
    Sure you can use the Phone.
    The K6000 Series has support for 2G 3G and 4G Networks.
    You don't need a new Phone I think your Provider try to make some money.
    Regards
    Neomode
      Not sure...
      from what im reading..default network in AU = 3g 850 ( what i think k6000 doesn't do )
      checkout coverage in AU...and check where you life
      http://maps.mobileworldlive.com/netw...name=Australia
      just wait and see..is also a option
      info:
      cheers
