S805 Device Bricked ? - Only Red Light - Board HD18Q V2.0
    This box have been bricked, after installing openelec zip package from stock recovery of the device.
    Now it only stays with red light only, not showing anything on TV.
    I have been able to boot into "TWRP Recovery for MXQ Devices" with different u-boot.bin files with BootCard Maker, but i believe that partitions have been corruped or something similar as all of partitions shows 0MB Size.
    Also i cannot format or wipe data on partitions as TWRP produces errors such as "cannot mount /data", "cannot find /bootloader partitions.
    The device is recognized into PC in the moment i put USB Cable into OTG port, without pressing recovery button into AV hole.
    So i was able to try dozens of different firmwares, but all of them fail at 4% with "UBOOT Disk Intialize Command" ERROR.
    Does anyone have any idea which firmware or u-boot files may works for this kind of device.
    Platform : Amlogic S805 ( 1GB ram + 8 GB Flash )
    Board Model : HD18Q_V2.0 with date : 2015/08/08
    Nandchip : Sandisk P545105231 from SDTNRGAMA-008G Series ( Taiwan)
    Wifi Model : Realtek RTL8188EUS
    DDR : 2 x DDR Marked as PE039-125 TP ( this might be Spektek DDR?)
    which usb tool are you using
    i cannot connect to usb
      Hmm..
      Install from zip.. only works on realy old versions of openelec/libreelec ( i think v5 )
      newer version no-longer support this abilty
      I would try libreelec as it runs fully from sdcard
      DISCONTINUED: These builds will no longer be updated but you are welcome to use them! LibreELEC 8.2 for Amlogic S805 devices. Important notes: These are unofficial, community supported builds so please post all bugs/issues in this forum area only.…
      I was thinking about using mine s805 as pi-hole... but never got around to it ( addon pi-hole for libreelec )
      goodluck
