Scishion V88 hard bricked
Hi, so got the Scishion V88 last week and it worked good. But since Saturday the box suddenly went in a bootloop. Today the box doesn't even turn on, with only a faint red light visible. I tried going to recovery mode using power and reset button, to no avail. Finally opened the box and tried to use Pin method, still box doesn't get detected by the PC. Please help, any and every help would be appreciated. I was shorting pin 6&7 as well as 29 & 30. This box is a newer MX4N-V20 version. The picture is attached below. Thanks!ÂYou may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
Originally posted by Transporter_15 View PostHi, so got the Scishion V88 last week and it worked good. But since Saturday the box suddenly went in a bootloop. Today the box doesn't even turn on, with only a faint red light visible. I tried going to recovery mode using power and reset button, to no avail. Finally opened the box and tried to use Pin method, still box doesn't get detected by the PC. Please help, any and every help would be appreciated. I was shorting pin 6&7 as well as 29 & 30. This box is a newer MX4N-V20 version. The picture is attached below. Thanks!Â*
short pin 5-6 on the lower right side
Rockchip Batch Tool v1.7 firmware failed
MX4N-V20 version
is there a firmware?
I also managed to find the right firmware
Originally posted by hydix View PostHey guys i am new here , i have the same problem. Well i bought 2 box scishion v88 one i managed to root and update to a new firmware from gearbest and now is working good but the other i didnt rooted and updated and now is having red light and computer doesnt detect it what can i do ?
Originally posted by hydix View Postyes it is
downloaded DriverAssitant_v4.4 for pc-decoder drivers
1)first install Driver Assitant_v4.4
2)from photo SHORT CIRCUIT pin 5-6 on the lower right side see photos
3)Short circuit 5-6 pin.
connects usb pc-decoder socket
Once connected pc-decoder remove the tweezers in the short circuit pin 5-6
this point you should have connected decoder-pc
4)use Rockchip Batch Tool v1.7 to send the firmware
pso not use the power cord current
I'm Italian and I have to translate English
Let me understand
communicate pc decoders with Driver Assitant_v4.4 drivers run short on pin 5-6?
Or have you tried to send the firmware with Rockchip Batch Tool v1.7?
If you make a mistake with Rockchip Batch Tool v1.7 I think the firmware is not compatible.
You have to find your original firmware
Operating system I have this: Android Marshmallow 6.0
see the version of your motherboard Rockchip MX4N-V20 MX4N-V03 MX4N-V02 ??
you also have to see the integrated wifi card
I have this ssv6051 card
SEARCH YOUR FIRMWARE EXAMPLE: V88 MX4N-V20 ssv6051 Android Marshmallow 6.0
I repeat this is an example
you have to check what you have inside the decoder and do this research according to its features
download the firmware until you find the right one
Originally posted by mlung71 View PostYou solved??
There are currently 2231 users online. 1 members and 2230 guests.
