M96X VBOX Colorful TV Box 905X 2/16GB fast Lan 2.4GHX WiFi BT4
    Model: M96X VBOX
    Type: TV Box
    System: Android 7.1
    Processor: S905X
    CPU: ARM Cortex-A53
    Core: 2.0GHz,Quad Core
    GPU: Mali-450
    RAM: 2G RAM
    RAM Type: DDR3
    ROM: 16G ROM
    Max. Extended Capacity: 32G
    TV Box Features: 5.1 Surround Sound Output
    Decoder Format: H.265
    Video format: ASF,AVI,DAT,ISO,MKV,MOV,MPEG,MPG,RM,RMVB,WMV
    Audio format: AAC,APE,DDP,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Antenna: No
    Camera: Without
    Language: English,French,Germany,Italian,Spanish
    DVD Support: No
    HDMI Version: 2.0
    Other Functions: 3D Video,External Subtitle
    External Subtitle Supported: Yes
    HDMI Function: CEC
    Power Comsumption: 2.5W
    RJ45 Port Speed: 10 / 100M
    System Bit: 64Bit
    WiFi Chip: AP6335
    System Activation: Yes
    Power Type: External Power Adapter Mode
    Product weight: 0.3000 kg
    Package weight: 0.4200 kg
    Product size (L x W x H): 11.80 x 11.80 x 2.30 cm / 4.65 x 4.65 x 0.91 inches
    Package size (L x W x H): 21.00 x 15.00 x 5.20 cm / 8.27 x 5.91 x 2.05 inches
    Package Contents: 1 x Smart TV Box, 1 x Power Adapter, 1 x Remote Control, 1 x English User Manual
    Gearbest
    M96X VBOX Colorful TV Box 905X 2/16GB fast Lan 2.4GHZ WiFi BT4
    Well After the last 905x, today we can add some colour into things,
    M96X VBOX, Android 7.1 S905X 2G/16gb Fast lan,2.4GHZ Wifi and BT4
    Whats in the Box
    One Shiny box something for those stingy fingers
    No Leds on tops/see thru but a stip of something going to happen across the front.
    Ports to be seen
    Some Venting
    A bit look on the Inside
    Top Side
    Underneath, note quality stick tape holding the clear tubing into slot
    Closer top side view
    Ram don't recall this brand
    eMMC
    WiFi
    There we have the Box and Bits...bit of a tour around hardware looks ok, not a lot of ventilation Small heatsink stuck on good.
    Fire it up soon and see what it has to offer
    And The Power Led looks kinda funky...
      Interesting Looking device,
      Onto the Testing and whats going on inside...
      We do have root, and looks like it has been tweaked running upto 2016 mhz get a little warm..
      Running Android 7.1 performance is looking OK
      Only 2.4Ghz Wifi and Fast lan, chugs along ok so far
      Lets have a look
      Standard UI
      Installed Apps
      Android 7.1 no fancy seeting all basic
      Storage and Ram Truth
      Lan and Wifi connects
      DRM Level 3
      CPU-Z
      Ram has a bit of speed, help things move along a bit
      Testing so far and performance as seen is not too bad for a 905x
      Interesting design you either like it or not, different.
      Setup wizard on startup so very easy setup
      Wifi and Ethernet speeds are ok here.
      No troubles starting up, connection to Google etc all good.
      Remote control ok no problem in testing 5 meter range tested
      Also using Logitech Wireless Keyboard mouse all good.
      As mentioned we have Root, also Upper and Lower task bars.
      UI is ok the Help on menu takes you some website to dload
      Apps, Addons etc, not sure about all that.
      Some unwanted Icons in Upper task bar, can be removed
      Also some apps not running full screen, so some work needed there
      Temps of this Box are Fair when idle below 40C when pushed up in the 60's seen
      Due to the Overclock or whatever they did to achieve this.
      Hardware seems OK, Heat sink not sitting Square to CPU, so some of the CPU has some Heatsink
      Ram brand unknown at present but performance looks ok
      Connection to BT speaker ok and streaming YT 1080p WiFi and BT no problem found here.
      Full size SD card used, like that compared to those fiddly little suckers.
      With all the work about on Amlogic 905x Boxes no doubt a custom rom is just around the corner.
        Excellent presented tv box as always. Is there space for a larger heatsink?
        • trebor
          trebor commented
          Editing a comment
          Could go a little larger, site atop a small fan would be the easiest..
        Kinda looks like the geekbox but more bling color...
          Good look,good hardware, but i never see so bad software. I never see 4k so laggy...even 1080 is dream for this crappy soft...Try to boot to LE,dont work ... Do someone knew better firmware it looks like dolamee,but im not complitely sure. With factory firmware is total crap ..i test more than 100 units,but never see so crappy .Even worst MXQ qith recycle ram plays better multimedia .Do someone know who is manifacturer and how to get newer firmware
            Finally find alternative firmware that works. Nano rom for minim8s find even wifi drivers,but i cant make remote works. I copy remote conf, change to rw - r-r but still no luck .Can someone help me ..i have original remote conf files from other device-same model
              Please any who has this box, please send me the IMG file or TWRP backup from pictures above by trebor. It is
              S905031-userdebug 7.1.1 NMF26Q 20170622
