New firmware v1.4.6 version for ZIDOO X9S Now
    1,Fix the issue that flv streaming is not playable.
    2,Adjust the accuracy of IR receiver.
    3,Fix the error of playback in APE music.
    4,Fix the issue that stream get stuck in some streaming apk.
    5,Optimize the transmission of USB 3.0.
    6,Fix the issue that the sata hard-disk can't be read after the wake-up of box.
    7,Fix the unexpected displaying of loading infomation when stream Iqiyi videos.
    8,Fix the issue that the box can't be wake up when USB 3.0 is connected with a usb stick.
    9,Fix CEC failure after wake up the box.
    10,Fix display failure when HDMI IN comes with 1080i video source.
    11,Optimize the system stability.
    12,Fix the problem in the simultaneity of audio and video in a certain App
    13,Improve the compatibility of rtsp and rtmp streaming
    14,Fix the black screen problem occasionally happens to a certain App
    15,Fix the error happens to continuous switching channels in a certain App
    16,Fix the failure to get audio tracks from online videos by system video player
    17,Fix the black screen occuring to some receivers when the Deep Color is set to Auto , Color Space is YCbCr444 and resolution is [email protected] in the meantime.
    18,Fix the problem unexpected reboot during standby mode
    19,Nuplayer support Dolby and DTS passrough(Online stream)
    App:
    VideoPlayer:
    1,Improve the experience of operating progress bar.
    2,Fix the reading issue of BDMV titles.
    3,Optimize the shortcut keys for switch audio tracks and subtitles.
    4,Fix the issue that some subtitle can't be download.
    5,Fix the issue that some subtitle can't be displayed properly.
    6,Fix the issue some mkv files display two subtitles at the same time.
    7,Fix the malfunction of bookmark.
    8,Improve the playback of UHD bluray movie.
    Musicplayer:
    1,Fix the listing information of some APE and FLAC can't be read out.
    2,Fix the failure to fetch the singer information for some songs.
    3,Display the CUE list playing
    4,Save the song played last time and it’s process.
    5,Add CUE support for WAV and DTS.
    QuickSettings:
    1,Add a Auto23.976/24 for 4K switch
    2, Add a switch between Nuplayer and Dvdplayer for online videos playback
    File manager
    1,Improve some translation
    2,Fix the malfunction of classification.
    Blu-Ray:
    1,Fix the movie don't pause when press the OK key for the first time in the playback.
    Shortcut key
    1,Add delete key and multitasks function
    Theater
    1,Fix the problem the videos won’t be played if you add a root path of NFS.
    Openwrt:
    1,Support more languages.
    Source Zidoo
    v1.4.6 for ZIDOO X9S
    Updatelist:
    System:
    App:
    VideoPlayer:
    Musicplayer:
    QuickSettings:
    File manager
    Blu-Ray:
    Shortcut key
    Theater
    Openwrt:
    Full_OTA_Package(User data won’t be wiped.):http://www.mediafire.com/file/n873p7...6_20170623.zip
    China mirror:链接:http://pan.baidu.com/s/1jHPj7N4 密码:2k4l
    MD5: 77055512CA6AB0C388DA61856E645DCB
    How to upgrade
    ZDMC:http://www.mediafire.com/file/n99ucx.../zdmc-17.1.apk
