Here is coming Android 7.1.1 for GT1 Ultimate!
Current Version: GT1_702NO_3G
Based Version: No
Android Version: 7.1.1
Board Configuration:
Master Control: S912
RAM: DDR4 3GB
ROM: EMMC 8G/16G/32G
WIFI & Bluetooth: QCA9377
Ethernet: 1000M
Package for USB cable:
https://beelink-my.sharepoint.com/pe...EOGBhyPhrijM78
Package for SD card:
https://beelink-my.sharepoint.com/pe...Olx5iBGBmKCPII
USB cable Flashing Tool:
https://beelink-my.sharepoint.com/pe...3yFKJeCJTLcAHU
Modification:
1. Support remote with 12/31/34 keys
2. Static and dynamic Beelink logo
3. LED light can be turn on and turn off
4. Support install APP which is not from Google Play
5. Default cancel validation application
6. Default open WIFI
7. Bluetooth keyboard is in accordance with model
8. Modify dialog string to adapt with BOX product
9. Default support 5G WIFI for all country
10. Remove the obvious invalid-program in system
11. Add Google package
12. Open Root
13. Add Light Home UI and WhatsFish HD
14. Remove QODI immersion when first start up
15. Modify the ROM to show theoretical value
16. Support FOTA online upgrade
17. Support HID device
18. Support NTFS/CIFS files system
19. Remove some unnecessary APP
20. Remove Dolby&DTS option in the Setting
21. Support DHCP KEY 1.4 TX
22. Support some flying squirrel and joystick
Mele F10/Hausbell_Mmini_i8/Rii_Mini_H7/XBOX/PS3
23. SNTP(Synchronization network time server)
24. Remove upgrade in settings
25. OTA Upgrade 2 change into FOTA
26. Support customize Bluetooth MAC
27. Default Latin IME
28. Add launcher
29. Support network ADB
30. Support sleep, shut down and restart
Please contact me: beelinkservice@bee-link.com
