Magicsee IRON 905x Unboxing and Tear down
    Hi Everyone
    New box thats kinda cool design. Lights vents even spot to hang it on the back of tv.
    905x
    2.4 Wifi,
    100 Lan
    2 Gig Ram
    16 Gigs storage
    Led Top lights
    2 usb
    Ir
    Remote Contol
    Power supply 2 amp
    One hdmi
    Same instruction manual.
    So into it. Its got a wierd shape (I like wierd so plus for me) led are on the top. But I think this a first the box has no screws the board is held in place again without screws. Was a great puzzel to open and check the parts. But heres the photos. As always more to follow.
    https://www.alibaba.com/product-deta...646983532.html
    https://m.gearbest.com/tv-box-mini-pc/pp_631781.html
    Click image for larger version  Name:	20170624_195318-747x1328.jpg Views:	1 Size:	108.6 KB ID:	653254Click image for larger version  Name:	20170624_195456-1328x747.jpg Views:	1 Size:	99.2 KB ID:	653255Click image for larger version  Name:	20170624_195537-747x1328.jpg Views:	1 Size:	161.0 KB ID:	653256Click image for larger version  Name:	20170624_200439-747x1328.jpg Views:	1 Size:	103.0 KB ID:	653257Click image for larger version  Name:	20170624_200434-747x1328.jpg Views:	1 Size:	135.2 KB ID:	653258Click image for larger version  Name:	20170624_200442-747x1328.jpg Views:	1 Size:	99.7 KB ID:	653259Click image for larger version  Name:	20170624_200447-747x1328.jpg Views:	1 Size:	101.4 KB ID:	653260Click image for larger version  Name:	20170624_200501-747x1328.jpg Views:	1 Size:	131.0 KB ID:	653261Click image for larger version  Name:	20170624_183708-1195x2124.jpg Views:	1 Size:	129.3 KB ID:	653262Click image for larger version  Name:	20170624_183726-1195x2124.jpg Views:	1 Size:	92.5 KB ID:	653263Click image for larger version  Name:	20170624_183737_HDR-1195x2124.jpg Views:	1 Size:	104.7 KB ID:	653264Click image for larger version  Name:	20170624_183958-1195x2124.jpg Views:	1 Size:	112.8 KB ID:	653265Click image for larger version  Name:	20170624_184110-1195x2124.jpg Views:	1 Size:	111.9 KB ID:	653266
    Click image for larger version  Name:	20170624_184034-1195x2124.jpg Views:	1 Size:	95.6 KB ID:	653267
    So far we have a host of custom roms that will work on this device. Super Celerons Atv/Just going through them all but seems Xanny and few others even my v88 port works on it so lots of options for this device. Ill check thtough them all to see if remote fix needed for some but that easy fix. Loading 7 next but so far good parts and everything works as it should
      The Android 7
      It works well few new apk that i testing out but seems the version i found also remote everything working. Going to test for few days but all in looks like a lot of roms work out of the gate so thats a plus for it hardware solid so get order ready Clark
        It's certainly a funky little shape.
        BTW what is the name of the blur filter you use on your camera, as it's very effective :-)
          Nice to see in back in full spirits
            Its called Old Age. But I know youve Forgotten what question you asked already
              Got my Mojo back and going to use it.
              What was I saying again?
              How is the heat dissipation on this one?
                Actually surprised its cool running alot of moded firmware so far. 7 bit buggy but that typical. Supercelerons Atv works fine... All in running pretty snappy on all so far but stock crap but thats kinda normal lol
                  Good stuff.
                  Look forward to hearing more when you test.
                    New Rom
                    http://freaktab.com/forum/tv-player-...-wifi-fast-lan
                    Also working on this device are the following
                    http://freaktab.com/forum/tv-player-...see-first-post
                    Change remote.confg (save it from stock in system/ect/ and just replace in new rom)
                    http://freaktab.com/forum/tv-player-...atv-android-tv
                    Again change the remote config file and everything working. Zip file for wifi in his post.
                    http://freaktab.com/forum/tv-player-...b-wifi-rlt8189
                    This is Android 7 it actually runs well no root or recovery and is where iam stuck right now as no pins on main board to short. So next post will how to recover bricked box lmao... Funny thing is even the remote works on this firmware but it bricks device from being seen in burn tool so DO NOT FLASH THIS FIRMWARE. unless you wana join me in the lets see how we un brick this now Class.
                      Look on the bright side.
                      You get to discover something new.
                        Ok After having apart for long time finally got it re flashed with the stock firmware so it can be seen by tool on pc. Upgraded to latest stock and ui ok wifi strong. The photos below are of the stock rom. Kinda little diffetent but standard bloat ware in it.
                        Heres the photos. (No ​screen shot on the stock firmware but shows Enough to get the idea of looks)
ID:	657589Click image for larger version
ID:	657590Click image for larger version
ID:	657591Click image for larger version
ID:	657592Click image for larger version
                          Now for the good News Super Celeron Atv Firmware runs PERFECT on this device. Once installed just enable root in settings then change the Remote config File. I will upload it and put a link in first post.
                          Seems We get alot of supported Custom Rom that will work out of the Gate for the Iron and any time we dont have to use Stock its a bonus (Because lets face it not many are very good out of the gate)
                          So final verdic nice box. Runs smooth. Bit of hickups on stock. But Tons of supported custom roms for the device.
                          Just dont use the U2 7 Firmware youll be sorry lol.....
                            Nice work Scooter and SC.
