WIFI DISPLAY
The link was for rkremote not wifidisplay were can I get the WiFi display app for my phone or tablet?Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
AW: WIFI DISPLAY
Originally posted by neodoom View PostThe link was for rkremote not wifidisplay were can I get the WiFi display app for my phone or tablet?
And
_________________________
tapatalked from GalaxyS3
Originally posted by smithmal View PostTechnically you can't copy apk's as there are already unpacked in your tablet. I believe there is a app though that will repack any app back to an apk...
APK Creator
smithmalAttached Files
AW: WIFI DISPLAY
Originally posted by auldthief View PostI am attaching the wifidisplay apk here. This does not install on my Lenovo K900. It says "application not installed". I think it requires signing. Tried zipsigner but no cigar. I hope it works on your phone-TVbox combo. Can anyone tell me how to get this installed on my phone?
screen mirroring in rk3188 kit kat 4.4.2
Originally posted by FadeFx View PostIt needs to be pushed to system/app/ but it wont work because it requires some libs as well afaik
Originally posted by aerolele View Posthi ....i have a measy u4c tv box and running kit kat 4.4.2 but there is no wifidisplay App!! i can't make screen mirroring to work!! i am using a Samsung galaxy s4 (modified rom ....it worked with 4.2.2 on the u4c)
As for android box i have Airplay DMR, wifi display.. on my galaxy i have wifi display helper. that allows the connection. I have to add if your using wifi helper you will need root on your samsung device. if you download kingo root to a pc, root your tablet, install an su .apk thats half your battle won.
could someone help me with mobdro as it keeps telling me to check my connection?
Many thanks
There are currently 2335 users online. 1 members and 2334 guests.
