H96 Plus 905 processor in need of firmware.
Originally posted by piperider View Post
no I haven't I don't want to mess it up any worse than it is but I'm struggling to find the original file for it ive searched everywhere
Do you know how to replace firmware's?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
It is hard to brick the Amlogic boxes. Give the Beelink MiniMX3 firmware a try, worse case, you would loose WiFi, Bluetooth and your stock remote. If that firmware doesn't work, try aother one.
Open it take some photos of pcb and wifi chip and post it otherwise. Ask manufacture to send you link to firmware. Most dont reply so its take your chances stay with what you have or do some work on your end open box and post so others can help you. Anything we tell you to try is a guess at best. So kinda out of luck at this point. But if you dp post some photos i am sure someone can point in correct direction.
There are currently 1662 users online. 0 members and 1662 guests.
