Hi randy I flashed rileyrom1.2 tnx a lot. Multi window works great but if I turned off multi window I can't switch to another app by using the task switcher. I have to press home then task switcher in order to go to another opened app.
Pipo U8 RileyROM 1.1 [Feedback]
Re: Pipo U8 RileyROM 1.1 [Feedback]
That same thing is happening on the M8 Pro firmware. Hopefully Pipo will fix this. I don't use multi window but I leave it turned on. It doesn't bother me to do so.Randy
Go to settings. Its right there on the main settings screen.Randy
Originally posted by francisaaron View PostHi Randy, Can i try your rom v1.2? When will you post this rom? Is your rom support the multi windows function like the #328 rom from other forum?
BTW, thanks for the effort in creating rom for our U8.
Originally posted by iobelika View Postthe 1.2 ROM is on number #23 post at this thread you can download it and flash it , and yes it has the multi-window function because it is based on the beta #328 ROM
Originally posted by rrileypm View PostSorry, this ROM does not come with CWM, because there isn't a current CWM Recovery by Fun customized for this tablet...it is only stock recovery.
If you want, you can download the generic CWM from here.
CWM Generic
Extract recovery.img from the zip file and flash it in place of the recovery.img within the ROM kit.
When you first boot to CWM...clear the cache to format it...then reboot the tablet. You will need to go into settings and mount the NAND storage manually. It will give you an error that says "damaged storage" in the notification area. Just press that notification and choose format...this will manually prepare your NAND storage (internal SD).
I hope that helps.
Thanks.
Have you tried to scroll up and down using the touch screen?
Otherwise, sorry...it won't work unless we get a custom CWM for this tablet.Randy
Originally posted by rrileypm View PostHave you tried to scroll up and down using the touch screen?
Originally posted by pts78 View Postwhat class of memory card? must be 10-th class
Games like avengers, real boxing, nfs most wanted and hot pursuit, asphalt adrenaline are running smoothly with no lags.
Games that I can't play are dark knight rises ironman 3 and six guns, any advise?
Thanks.
There are currently 2708 users online. 1 members and 2707 guests.
