This time a very simple rom since its enough for this device!
Many thks to gearbest for sending me the device to play
Many Thks to my beta tester trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
Changelog Beta V1:
- Based on stock
- General optimization.
- Youtube 4K (May be a little to much for 1gb of ram... but it works)
- Added power button to navigation bar, single press = sleep, long press power menu.
- App switch moved the close all open apps to the right
- Status bar auto hide, so dont show anymore on Youtube and other apps!
- Proper root!
- Added Lighthome Launcher!
- Organized some boot scripts.
- Added lots of kl's.
- Netflix, youtube, playstore...etc... fully working.
- Xbox360 Gamepad Wired and Wireless support.
- Gaps Updated
- Permissions fixed.
- Added Kodi 18 Nightly since is the only one that work good on this box
- Added a few apps...
- And some other little stuff...
- Setup wizard dont start automatically it need to be manualy executed...
- Setup wizard dont resize the screen to 100% even it it says it is... go to settings and resize.
- SuperSu cant update the binary, ignore it... since is the latest one 2.82!
- Browser icon on Lighthome launcher dont work!
- You may have a quick green screen at boot... nothing special ignore it!.
- Possible lot more Bugs...
Want to buy me a beer?Download:
- DOWNLOAD HERE SCV1-Beta for the A95X-R2
- MD5: 6A244DB9BF276888ED297DF81CD2435B
- Search the forum for instructions!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
