[GUIDE] Install magisk and pass safetynet (protected apps fix) for GT1_701N0/702N0
Aldo_97,
i have followed your guide to install magisk. i was unsussesful !!. i did it with orignal 705NO and 707NO.
I started out by flashing a fresh image of 705NO or 707NO via USB all went well
then proceeded in install terminal.apk so i can flash twrp.zip. all went well
I then copied all your files from your guide in external sdcard in gt1 beeling
boot in twrp and proceeded installation one at the time with Unsu, busybox uninstaller. it went well
then when come to Magisk . it gives error 2 can't find boot image or boot has been modified. when i edit util_function.sh script file to boot find, it still don't work
at the end it can't get the magisk to be installed properly. what is wrong?
i am trying to unroot device so i can watch att u-verse. currently block i think due to drm content
if anyone can provide me with a good magisk.zip install via twrp
Guus, i have place the twrp zip file for you on google drive to flash using terminal apk. follow the readme instruction https://drive.google.com/drive/folde...Ua?usp=sharing
Originally posted by Guus View PostWhere can i find TWRP for Beelink GT1 Nougat 7.1.2, i look everywhere but I've not found it...could someone kindly point me to the thread or the links where to download?
Originally posted by Guus View PostThis guide is not working for me, no matter which method i follow, magisk always says to restore original boot image and fails...any suggestions?
I have the same issue. the magisk.zip script is not setup correctly for the boot file. even though the boot is original it was just flashed from beelink image. only twrp recovery image was changed
Edit-----
However I have successfully installed it (some month ago) on 705N... Could you repeat me what you have done? Thanks
Originally posted by Aldo_97No problem here with latest firmware
Sent from my Beelink GT1 using Tapatalk
Originally posted by buggerritt View Postfrom which firmware? 707NO? I am currently using stock 705NO. Everything is running great. I just want to install magisk. Should I follow the directions in the OP? It seems both the links for busybox uninstaller and selinux enforcer are no longer valid. I also am having difficulty installing twrp. I place the twrp image for q201 board on the root of my external sd and rename to recovery.img and reboot to recovery but instead of twrp, it boots to stock recovery. Am I doing something wrong? My sd is exfat. Should I format it to something else for this process? Does it need to be empty aside from the twrp image?
There are currently 3625 users online. 0 members and 3625 guests.
