I have a problem with connecting my snakebyte idroid:con controller with my UG007B android 4.2
UG007B found the snakebyte idroid:con controller , but problem with pairing and connecting with it.I did every thing as in manual ( snakebyte idroid:con controller).
can you connect other BT devices ?
like mouse etc ...
if not here is something wrong with your Bluetooth.
try that first .
you can try other roms .... I use the sam321 kernel and my BT mouse works fine.
