[Question] Best Firmware Android 6.0 for v88 Tv Box [1GB/8GB][RK3229]
Originally posted by gefattern View PostHi Novato ,
if you mean this Box :
you can use , i think the Ugoos UT6 Firmware , somewhere
here is a Thread about it , but can not find him now .
good luck
gefattern
Thanks for replying, I have done some tests, I have already tested this Ugoos UT6 firmware, it is great, but unfortunately it has problems for my box, lack of Wi-Fi chip support, lack of infrared support, and problem connecting and disconnecting . Apart from that it is the best I have found so far, sorry that lacking community support to adjust this ROM to other devices with Shipset RK3229, which is a great chip, but lack optimization in the software to extract the maximum of the processor. Well I'm excited to find new options! If you know other ROMs do not exite in comment! : D
Thank you.
Hi, Novato.
Did you have success with a firmware for this Scishion V88 4K? My unit arrived with Android 5.1.1, and I can't watch Netflix on it (audio and video are out of sync). I'm looking for the best firmware to flash my device, but I'm not sure that the devices that have Android 6 are the same devices that have Android 5.1.1.
There are currently 1622 users online. 1 members and 1621 guests.
