Here come new arrival TV Box R-TV BOX S10, loaded with KODI 17.3, Amlogic S912 processor, support with 4K Output, VP9 HDR. the only one tv box install Kodi 17.3.
There are many decent Android TV boxes that will play Kodi well and stream movies or TV shows from online sources. However, if you are looking for the best possible one loaded with KODI 17.3, then R-TV BOX S10 is the best unit available.
KODI 17.3 Krypton
Amlogic S912
There are many things to like about the R-TV BOX S10 from the fastest Amlogic S912 processor to 4K video streaming possibilities.
3GB/2GB DDR4 RAM + 16GB/32GB eMMC Stroage
The Minimum requirements to look for in a Kodi android TV this year turn out to be a box with at least 2GB of RAM and at least a S905 or better CPU. R-TV BOX S10 goes off the beaten track by embed in its compact housing a 3GB/2GB RAM of the latest DDR4 standard as well as 16GB/32GB eMMC storage. It is likely that BOX S10 will hold an adequate amount of apps you may throw at it with plenty of room to spare.
Android 7.1 OS
Designed to shift your standard-looking TV into an Android device that will make it a super smart entertainment center, R-TV BOX S10 is surely an elegant looking Android TV Box that runs on Android Nougat, the latest and greatest operating system developed by Google.
