As soon as you boot up the TVCenter it tells you that you can update to 17.3 which is recommended, now if you do that it doesnt update the TVCenter it installs a fresh install of Kodi 17.3 and a new icon as you can again see from the image which ive placed there
Now i would like to keep the launcher pure so that when you click on the TVCenter icon it fires up the updated version of Kodi
Is there any way i can do this?
ie. modify the launcher menu?
Cheers
