Scishion v88plus 4k firmware? What is the wifi etc...
Can I use another devices custom firmware and if so what one? The video sync is just bad... And I need a fix...Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2Tags: None
One of the chips on the board will identify the WiFi.
Quite often it will start with AP and as an example, could look something like this.
http://datasheetcafe.databank.netdna-cdn.com/wp-content/uploads/2016/03/AP6330-image.gif
in the second pic is the wifi chip its a 6051p and the gear-best site v88plus firmware's don't work i now have non working wifi on the test unit (i have 6 of them at the moment and they have very bad video drivers for lip sync) i need a custom firmware im suspecting and if some one knows one compatible with rk3229 and 6051p wifi i will be very happy!Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
Very difficult to see my friend, that I know there is only one incredibly powerful Firmware that will work on your device, the Firmware Ugoos UT6 1.2.0, for the device of the same name. This firmware supports 1/2 GB of RAM, is compatible with most RK3229 devices, but has another Wi-Fi chip and has no IR Control Support. Fortunately with effort from the members of the Freaktab and the 4PDA Forum, there were 2 patches with a Kernel to correct
Wi-Fi, which breaks down some functions of the device, and another by a member here of the forum, without kernel, with Wi-Fi fix and IR Controller Support (IR Control does not work 100%). Other than that, there are not many options, I was also disappointed with my Box as soon as I tested it.
There are currently 2916 users online. 1 members and 2915 guests.
