Bought from Azurill on amazon.co.uk for just shy of £60 and came in a tatty box with wrong plug (2 pin not 3 pin UK).
Does it get better when you plug it in? No. Not at all. Tried two 2A chargers (Nexus 7 charger and a spare I had bought) and it gets hot really quickly. Decided to run stock rom for a bit and see if there were any other issues before I flashed it as didn't want to needlessly invalidate my warranty. Thank godness I did! Firstly the wifi connection showed full bars but internet browsing and using google play store was painfully slow. Ran a speed test app to see what was going on and got a ping in the 900ms area and download speeds of under 0.3mb/s. Ran the same app on my Samsung phone at the same distance from the router and got 62ms ping and 30mb/s. Not only this but whenever it was trying to do something over the wifi it seemed to massively negatively impact the wifi connection of other devices (such as PC and mobile).
Tried to play several films from my samba share using BSplayer and MXplayer and they failed. Tried playing it over minidlna without luck too. Not as in jitters or stutters but as in never even started playing... Tried Netflix and the quality looked like it was filmed with a mobile phone camera from 2005 from a dodgy pirate copy played in a underground cinema in China. I am utterly disappointed with this stick. Had reasonably low expectations after reading about the movie jitters etc but this device is just plain unusable! £60 should buy you a workable device. Decided against flashing roms etc. in case it prevented me returning it under warranty and will be shipping it back to Amazon tomorrow.
Unfortunately (and this is the biggest problem so far) I have caught the android stick bug. I've had a (well two actually) raspberry pi for a while (whacked one in a zx spectrum case with pretty much every zx spectrum game ever made in it and even using the rubber keyboard, the other sits upstairs being my print server and media server) and played with that a fair amount but the idea of a more powerful stick device that I can use apps bought from the google store intrigues me. Want to be able to watch Netflix and stream movies in web browser. Also means I can use it to learn how to build kernels and roms without buggering up my phone.
Can anyone recommend me a device which might suit this without breaking the bank? Are the new RK3188 sticks using AP6210 wifi chips better or do you still need a USB to ethernet dongle?
Any suggestions will be gratefully received and much appreciated
empty
