GT1 /703 NO firmware/standrad / ultimate edition /(2G+16G/2G+32G/3G+32G)/QCA9377(LTM8830)
    Hi everyone, here is the Android 7.1.2 for you!
    Current edition FGT1_703N0_LTM8830-Test
    based on FGT1_702N0
    Android edition F7.1.2
    fits for : DDR4 3G / DDR3 2G
    WIFI&BT: LTM8830 / AW-CM273SM(QCA9377)
    EthernetF1000M
    SD card zip :https://beelink-my.sharepoint.com/personal/firmwareservice_beelink_onmicrosoft_com/_layouts/15/guestaccess.aspx?folderid=10cd59b6a60c542728d2e4c6 8462faea0&authkey=Aclrj6S1lKvqG1BYR_m8Ruc
    USB zip :
    https://beelink-my.sharepoint.com/personal/firmwareservice_beelink_onmicrosoft_com/_layouts/15/guestaccess.aspx?docid=129ddc2ade3354df491a2ac1c6f 873af7&authkey=Afql1Ag7x_NWz38E5fpMOq0
    New burning tool for USB cable:
    https://beelink-my.sharepoint.com/personal/firmwareservice_beelink_onmicrosoft_com/_layouts/15/guestaccess.aspx?docid=1cbff1a470dc74c4cb19ec86095 89e89c&authkey=AbFkuaAYAcoK-dm4kmsvCs4
    Improvement
    1.Improve the problem of "the setting interface is opended slowly ".
    2.Improved the problem of "the bluetooth can't be connected with the Android smart phone"
    3.Improved the problem of "the other button is valid when you have a long press on the Menu button under the home inerface"
    4.Supports the AirPlayer IOS 10 .
    Welcome to tell me the bug you found:
    Email: [email protected]
    Beelink thanks for the updates! just keep them coming ✌️
      Thanks for the update Beelink. Quick question, I have the ultimate 32G/3G version, 9377 wifi chip (G912 SN). I found out that the bt audio is always stuttering no matter how close I got and after trying multiple pairs of bt stereo earbuds, still the same thing. Is this a known issue with a fix? Thanks a lot.
        On beelink's forum, it is said that the usb package listed here is the only method to update from android 6.1 version ROMs to android 7.1 (using usb burning tool and that img file, 900mb). The SD card package (three files, zip, recovery etc) is for update within android 7. Can we use the Amlogic Boot Card Maker to make boot sd (witht eh 900mb img file from usb pacakge) and update?
        Is this correct? Thanks
          Where is the update for the a912 model
            A912 fw:
              SuperCeleron is this beelink gti ultimate a 64bit box?
                nougat yes
                  Beelink is CIFS supported with this ROM?
                  Enviado desde mi GT-I9300 mediante Tapatalk
                    Hi dear this situation occurs with 703no?
                      On 703no (G912 3G+32G) i have some issues:
                      1. In launcher My Receiver Onkyo TX NR 414 loses audio signal every few seconds and my speakers clicking, a little helps disabling system sounds, but In youtube or other player all was OK...
                      2. No status bar, no bottom bar it's very uncomfortable...
                      3. On physical keyboard don't work language switching
                        I couldn't tell any improvements on BT audio particularly.
                          is it possible to flash with stock rom ?
                            the only problem visible that detected wen playing a video on kodi (FTMC) if u try to skip a little forward the program crashes !
                              A couple of problems...
                              1 some apps, once you open them, only display half the image. This happens with Fubo and Dazn.
                              2 Navigation bar at the bottom is missing and the app doesn't work from the play store. It just hangs on initialising.
                              Please help!
