Z83V Mini PC with VGA port support dual display
    Z83V has same size with Z83II, most specs are same, the only difference is Z83V has VGA port support dual display, while Z83II without VGA.
    What resolutions does the VGA port support?
      1920*1080P
        Originally posted by AZW View Post
        1920*1080P
        Thank you.
          Thank you.
          that's ok.
            Dear AZW, thank you for the informative topic. I recently purchased Z83-V and I am very happy with the device. However, I could not find any official drivers especially for Z83-V, only for Z-83-II. Could you be so kind and provide a link with pack of drivers and image of the 64bit Operational system, since if I want to fully reinstall the OS one day, it will ask for product code and this information is not included in the package. Thanking you in advance!
              With the specs being the same apart from the VGA port, you will almost certainly find that the standard Microsoft VGA drivers would be installed on detection if you were to reinstall using the Z83II recovery files.
                Hello.
                i got one of thease Z83V mini pc from Gearbest.
                I did a driver backup but stupidly forgot to backup /windows/system32/drivers/4345r6nvram.txt
                can anyone share me that file please ?
                mine come with AP6255 combo set in bios.
                best regards
                  Originally posted by t-minik View Post
                  Hello.
                  best regards
                  which drivers did you lost?
                    Hello, I did a driver backup first but what I need is the /windows/system32/drivers/4345r6nvram.txt file which activate wifi and BT.
                    Can you provide that file?
                      you can find driver here.
                        Hello dear AZW,
                        kindly please help me to find a bios file for my Z83V. I need the bios for win10 OS.
                        Initially was Linux, but now I bricked the Bios. So I need the .bin bios file to be uploaded to the bios chip with a programmer.
                        Thanks.
                          Originally posted by istvan58 View Post
                          Hello dear AZW,
                          Thanks.
                          ubuntu BIOS?
                            Hello,
                            I need the BIOS for WIN10. It was Ubuntu Bios but after update with Shell with a a bios I find on internet ( some Beelink) bricked my PC.
                            So need now tor re-flash with a programmer, already I removed the Bios chip but still have not the Bios .bin file which fit to my Z83V.
                              Dear AZW,
                              can you please help to find the Bios which I need?
