Brand: Beelink Model: M1 Type: Mini PC System: Windows 10 Processor: Apollo Lake N3450 CPU: Apllo Lake N3450 Core: Quad Core GPU: Intel HD Graphics 400 RAM: 8G RAM RAM Type: DDR3 ROM: 64G ROM Max. Extended Capacity: 128G |
Decoder Format: H.263,H.264,HD MPEG4 Video format: 4K,DAT,ISO,MKV,MPEG,MPEG1,MPEG2,MPEG4,WMV Audio format: AAC,APE,FLAC,MP3,OGG,RM,WMA Photo Format: GIF,JPEG,JPG,PNG Support 5.1 Surround Sound Output: No |
5G WiFi: Yes Bluetooth: Bluetooth4.0 Power Supply: Charge Adapter Interface: DC Power Port,HDMI,SD Card Slot,USB2.0,VGA Language: English,Germany,Italian,Japanese,Simplified Chinese DVD Support: No HDMI Version: 1.4 Other Functions: 3D Video,ISO Files External Subtitle Supported: No Power Consumption.: 12W RJ45 Port Speed: 1000M |
System Bit: 64Bit WiFi Chip: Intel3165 System Activation: Yes |
Power Type: Digital Power Supply |
Remote Controller Battery: 2 x AAA Battery ( Not Included ) |
Product weight: 0.2480 kg Package weight: 0.6390 kg Product size (L x W x H): 12.00 x 12.00 x 2.40 cm / 4.72 x 4.72 x 0.94 inches Package size (L x W x H): 13.20 x 12.40 x 9.00 cm / 5.2 x 4.88 x 3.54 inches |
Package Contents: 1 x Beelink Mini PC, 1 x Charger |
Beelink M1 Quad Core Mini PC 8GB RAM + 64GB ROM - 4GB RAM + 64GB ROM
GearbestLast edited by trebor; 12 September 2017, 02:05.Tags: None
Indeed.
I have been mulling over a move to Apollo Lake myself for few weeks now but haven't bitten the bullet, so wanted to see if this one could be in the frame for purchase.
But I have some observations/questions for Beelink that I hope that they can answer.
There seems to be no mention of this on the Beelink site, so is this a true Beelink product that will come with their direct support?
But in the mean time, going on the basis that it will be:
This M1 looks very similar in many respects to the AP34 and AP42 models. The AP42, at least from Gearbest site states that it is now discontinued and the AP34 out of stock.
Looking at things such as the addition of a VGA port, does this indicate that this new model is a direct replacement for them?
Nice to see the option of a 4Gb and 8Gb available but if somebody chooses the 4Gb, can they upgrade the RAM and if so, is it a case of there being a second memory slot or is a replacement of the 4Gb necessary?
Is the memory installed dual channel?
The Gearbest listing also shows 'DIY SSD' quoting 64Gb, 128Gb and 320Gb.
Does this mean that there may be the possibility of 3 purchasable storage options in the pipeline as I'm sure that whilst the current on-board 64Gb M2 SSD (thumbs up for M2 too if it's performance is far better than MSATA) can be upgraded, people might like the option of having the 128/320Gb options to purchase, without having to replace the existing model that may have no practical use for them elsewhere?
I just want to confirm that the HDMI port is 1.4 because now that we are seeing more Apollo lake boxes with the full 2.0a (albeit linked to an internal DP port) that offer the full 4K experience, it would be nice and perhaps even wise/expected to see this as a standard in all new models with this SOC.
Running on a max of just 12W is impressive and a good selling point for those wishing to get the maximum performance with the greatest energy saving.Last edited by bluesmanuk; 19 July 2017, 13:58.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Both the M1 and the AP34 Ultimate come with 64GB emmc with the option of being able to add to that with a M.2 SSD up to 320 GB
The AP34 Ultimate is indeed HDMI 1.4 so I would assume is the M1
Photo of the AP34 Ultimate PCB (Review coming soon,As you can see the PCB shows M1 on the Ap34 Ultimate)
Originally posted by blinkone View Post
The M1 use's the same PCB as the AP34 Ultimate the only difference iv been told is that the M1 has a VGA port
Look forward to reading your review.
Now let's have a look at the
Beelink M1 Quad Core Mini PC 4GB RAM + 64GB ROM
M1 Mini PC, Windows 10, Apollo Lake N3450, Quad Core, Intel HD Graphics, 4GB RAM DDR3 64G ROM
Thanks blinky saves me a bit of a tear down
The Very Colourful Beelink Box
Spec's
What's in the box, including Vesa Mount
All the ports USB 3 and Full size SD card
More to come...
Ok bit of a look see at what this can do
All Legit
Into the Creator update
System Info
Aida64 cool start
30 minutes later
Cool down slow, found it doing a Scan and update..
Crystal Mark
So for what it is, a good little unit great SOHO unit or something to have as a second unit to do the basics.
Video playback Ok Netflix Plex etc, should do most.
Lots of these small units about slowly upping the ante to the next chip all a bit of fun really
Thanks To Gearbest for the opportunityLast edited by trebor; 01 October 2017, 07:04.
There are currently 1804 users online. 0 members and 1804 guests.
