This rom couldnt have been done without Magendanz,Pinguy ,and Superceleron,That being said i have ported mostly from Magendanz Newer Build
This rom comes prerooted as i added viper audio with needs root to install driver .... this should give you HD Audio in SPMC depending on the passthrough settings you have
Dark screen fixed
Colour banding is good with 4k output
ddr is clocked at 792mhz
Issues
Cast Not working unless you cast from chrome
You tell Me .....
Excited by this rom. Runs very fast on the Mecool M8S Pro Plus (!) YouTube 4k is brilliant, as is video through SMPC and MX Player. Audio is BIG with Viper enabled. Menus snap along crisply, zero lag.
1. Storage tab in Settings reports that the rom occupies over 6gb of space with the system folder accounting for over 3gb. Preloaded apps only take up 796 mb..what is using all that space?
2. Trying to add wifi drivers for 9082C on the fly with a root explorer creates a bootloop. Please consider integrating those drivers into your next iteration. This is going to be a super-good rom for these s905x boxes.
i've found a bug :
my HDD (1TB)which formated NTFS and GPT it is detected as USB on ES File Explorer but wont be mounted, under Storage it's not detected.
It's not a problem under stock OS or any OS beside this one.
Hope there's a solution, because your ROM really promising on performance
