Been lurking in the background a while while trying to sort out my stupid m8s clone box. So decided to register in the last ditch attempt for help as I've read all the posts over and over but still can't sort it.
So in my stupidity I decided to try upgrade the firmware to get the latest kodi.
Found a few files online. But the first 1 I tried resulted in a bit.
I didn't back up as I was a bit nieve.
Using the brick recovery files I was able to get back to the interface. BUT when I reset or power off the box it freezes on the amlogic splash.
I've Tried every firmware I can find and none will actually load other than the brick recovery. They all either result in a brick with blue light on or a brick with no blue light and 1 instance of blue light on but black screen.
I've opened up my device and I have the AP6330 chip with board version 8_1 20150418.
I've never been able to boot into recovery and I also cannot get the device to connect to usb burning tool at all I've installed everything for that as per instructions and I've used 2 different pcs and 2 different usb cables. Made sure driver enforcement was off etc but I can't even get a connection.
I've tried the jumper method also with no luck and also pins on the nand
Can anybody help me out as I'll try anything at this point
Thanks in advance
