to be honest I just assumed this was working with 7+ images, I'm i mistaken in thinking that?
AmlImagePacker - Create a IMG file from the level1 folder without the Customization Tool
Originally posted by natinusala View PostI didn't know about that ! This is exactly what the function in the DLL does (config file, level1 folder and output image), I bet the code behind is exactly the same. Well that kinda makes my tool useless, unless you are stuck on Windows for some reasonLast edited by jit18; 24 July 2017, 02:32.
Originally posted by scooter2014 View PostYes tool wont repack properly on 7
Trying to pack a nougat S912 rom can unpack rom fine but program crashes in repack.
The linux tool i posted pack android 7.1.1 properly.Everything is possible if we work together!
You can unpack the image with windows customization tool than unsprase the system partition from lv1 folder using linux, mount, make changes, sprase it again and use linux tool to make firmware imgEverything is possible if we work together!
Originally posted by natinusala View PostThe ultimate goal would be to have a 100% open source Customization Tool clone, with a CLI and without the need of any Amlogic code/DLL (and the ability to load a previously unpacked ROM without unpacking it again). It would not be very hard to do, since we already know the format of most files and data, but it would certainly take a long time to have something as powerful as the current CT.
Customization Tool 9.5.8 (All versions of android) The tool supports Amlogic, Rockchip and Allwinner firmwares Download from my official website - Download Note: There is a free and a paid version. Free version still works fine for most uses...
Multiple tools for AMLogic devices, not a single library, binary or anything used from AMLogics software
Ive also created perfect unpacking, the abillty to export the unpacked content as a project, abillty to add init.d, etc etc
There are currently 2434 users online. 2 members and 2432 guests.
