I too was concerned upon how their software fix will affect my volume now I have corrected the hardware, but I was planning on crossing that bridge when it became an issue.
Pipo M6 - Speaker Imbalance fix
If you contact Jenly li @ pipo support - she might be able to hook you up with a new speaker. Be polite, explain that you are technically capable of doing it, and that you're aware and willing to accept the void of warranty.Support your local flasher
Current devices : Pipo MAX M8 Pro - Samsung Galaxy S4 - Intel NUC
How to open the Pippo tablet please?
It may sound stupid but I would like to do your trick and also repair the power plug as the tiny pin inside broke.
The problem is that I cannot work out how to open the tablet, would you mind posting a little picture on how to do this please?
Quite a few people are having this problem and send it back to China rather than opening it but the cost of sending it back is quite high. I hope there is an easy way of removing the cover without making any marks on the tablet itself.
I have the M6 3g and I am quite disappointed about the weight, OS stability and battery.
Thank you so much!
Steve
removing the m6 back cover
Originally posted by bambinou View PostHi,It may sound stupid but I would like to do your trick and also repair the power plug as the tiny pin inside broke.The problem is that I cannot work out how to open the tablet, would you mind posting a little picture on how to do this please?Quite a few people are having this problem and send it back to China rather than opening it but the cost of sending it back is quite high. I hope there is an easy way of removing the cover without making any marks on the tablet itself.I have the M6 3g and I am quite disappointed about the weight, OS stability and battery.Thank you so much!Steve
Done the mod today with success at my M6 max. The result is a difference like day and night. It works just like the posted manuals.
Thank all very much for the pictures and hints (e.g. to use a tape to hold the buttons in place).
Especially the pictures and writings from @pulsar123 are very useful!
I break up 2 plastic noses at disassembling but after reassembling all is in place and there is no noise if I press the tablet.
The sound is now much more louder and balanced well between left and right.
This is simply to say that i have done this mod for some months now, and -provided that one takes the extra step of stabilizing the speaker with ...something -if foamy then best!- ,it turns out just great.
Someone was obviously sleep deprived there at pipo to manufacture the tablet like this...
However i was considering a further improvement of the sound. How about, installing an extra speakerphone?
There seems to be ample space , at least on one side.
I could easily try it, but i got scared that if i chose the wrong type , i would end up frying my normal ones!!!
Could anybody provide a link to a speaker that would work for that senario?
Obviously i will solder it in parallel to one of the existing ones. If someone knows the appropriate characteristics, i would really want to try something to provide more volume to my pipo.
Thanks in advance
Power jack center pin loose fix
How did you fix the loose pin ? i have the same problem
Paolo.
Originally posted by winer View PostI opened my M6 after the center power pin came loose and i choose to give the diy fixing a try, with full succes.Take a credit card or some other plastic card and push it in the seam between the edge of the back cover and the thin plastic edge surounding the glass, start in the middle of one of the sides and slide it in the seam and carefully unlock the plastic hooks, when close to a corner take a second card and work on the oposite side to the corner and push it out., do not start with the buttons but save them for last ( by then the job is done), be carefull, on the connector side, it is weakened by the holes, Closing the two parts is easy, just click them together, but, use some thin tape and place it over the outside of the buttons in a way that they in there original position, ( use you nail) otherwise these little buttons keep dropping in again and again ( bringing you toward total madness)
There are currently 3858 users online. 1 members and 3857 guests.
