It shows that YGPS is working,but cannot access the location.
I think,something to do with ROM update.
The custom ROM build version of the Tablet is : KT107H_X_OTG
Build Number : KT107H_20161228
Kernel Version : 3.4.67
Baseband Version : MOLY.WR8.W1315.MD.WG.MP.V62,2015/12/23 21:57
Android version 5.0
Friends any help for upgradation of the ROM of this Tablet???
Looking at the tablet specs, it is based around the MT8752.
I don't know if there are any MediaTek devs around but I will move this thread to the area for MTK tablets as it may receive more viewing from those either with such devices or specialise in them.
But,CPU-Z says the SoC is Mediatek MT6592 with OCTA-CORE CPU
Whereas CPU-X and other apps says it is of Mediatek MT6582 with QUAD-CORE CPU
Could you Help me regarding upgrading of stock ROM?
Finding one that works is key.
Whilst there are many firmwares for tablets with this particular SOC out there, other tablets will have different WiFi chips, screen capabilities, 3G/4G capabilities, which would make firmware either completely unusable, or with only partial functionality.
With this being a relatively unknown tablet name, it may not be easy.
However, there are tablets, phones and boxes out there with different names but with the same specifications, often because they come out of the same factory but different vendors badge them up in different ways.
However, there is this thread on FT that may also be of assistance to you but you will likely have to do some groundwork first to provide all the necessary details.
the Wishlist is a nice Thing , if supported , never saw a Rom was made for a wish ,
best will be to use 3G dongle , if 3G is needed & GPS Dongle with BT GPS App from
Store .
Next Time dont buy from this FAKE SELLERS of cheap Tablets with wrong Specs .
good luck
geetings
gefattern
Thanks for the suggestion ,Friend.
In fact I forgot the age old advice "If it seems too good to be true,then it probably is ".
Nevertheless, wifi and all other functions of this tablet is awesomely great. NO PROBLEMS,NO ISSUES.
Android version 5.0
Chipset: Mt6582
Friends,do you have any link for STOCK ROM of this Tablet?????
I HAD BRICKED IT
PLEASE HELP!!!!!!
