I just loaded the RR1.9 for my Pipo M8 Pro. His 'Readme.txt' instructions are the best I have found. No real trouble at all. Loaded up and booted without a hitch!
Thanks ...Mr. Riley
.gif)
Note:
The only place I took pause was the instruction ..."Unmount and remove your external SD card".It registered on my brain after a few moments that meant to 'uncheck' that option in settings.
I had a Teclast a ways back, and any upgrade I did to that tablet required the option to be checked ...hence my hesitation.
