[ROM] Tronsmart S96 / Beelink GT1 Zombie Rom **9377 wifi ** 2G/16G
    [ROM] Tronsmart S96 / Beelink GT1 Zombie Rom R2 **9377 wifi ** 2G/16G
    Hey everybody heres a new rom for the tronsmart S96 and the Beelink GT1.
    Clean stock based rom with lots of tweaks and bug fixes.
    ***THIS ROM IS ONLY FOR THE TVBOXES WITH 9377 WIFI CHIP***
    This is my first public release of ZombieRom that has been tested since NOV of last year, Ive been unable to work for several years due to Spine and neurological issues so with all my free time i figured lets try and make a rom, took a lot of time to figure it all out but with some help from superceleron big thanks for source files and some guidance. I think Zombie rom r1 is ready for public release before this was only a private rom for our TS Team Zombie telegram group, if intrested in joining message me and we will talk about membership where you can have first access to beta roms and help the team with testing and debugging
    This rom is stock 6.0.1
    COMING SOON
    • brand new custom kernel based on custom toolchains have tested and is fastest kernel on any rom for s96
    • new PCM audio engine with better channel support up to 7.1
    • various audio tweaks from my work on xperia devices
    • other rebuilt modules to increase speed and performance
    • some other secret things im testing but will be well worth the wait
    • zombierom custom hphlauncher coming also
    • any suggestions? let me know
    Changelog R2:
    • just rebased rom with stock kernel and new audio files new audio libs from my xperia audio mod
    • some system tweaks for performance
    Changelog R1:
    • True 8 Core support all cores max out at 1.5ghz
    • gpu clock increased slightly to improve performance
    • Added various CPU governors
    • youtube 4k working full 2160p
    • multiuser support for families (each person can have custom setup)
    • auto hide on screen keyboard when external used
    • working netflix included (netflix from playstore seems to have issues with connecting)
    • HDMI passthrough support for kodi 17
    • HDMI self adaptation tweaks
    • HDMI self adaptation refresh tweaks
    • HLS support for HDMI self adaption
    • scaling issue fixes
    • Teamviewer remote control support (working with root)
    • black screen on video bug fixed
    • Permission support for ext4
    • newer GAPPS
    • Updated codecs for compatability and performance
    • box fix app added for CRC,brightness and rgb fixes
    • Superceleron setting for root and various tweaks **BIG THANKS SUPERCELERON best app**
    • Various other tweaks to EMMC,wifi,lan,audio and other systems files
    • Zombie rom boot screen and animation added
    • build.prop spoof for xiaomi mii box
    • Zombie audio engine first version (various audio tweaks to pcm audio system better fidelity)
    • Many usb device drivers added to kernel for various gamepads
    • Usb cameras may work havent tested it yet though
    • Xbox 360 controller support Dualshock 4 coming very soon
    • There are some other additions and tweaks that i can for the life remember
    BUGS R2
    • not sure let me know lol
    Bugs R1
    • If having CRC issues try box fix app and see if that works
    • Kodi 17 don't check dts HD capable reciever produces high pitch noise working on fix
    • Not sure as first release all bug reports welcome to help improve this rom for everybody
    Special thanks to:
    • TS Team Zombie members:
    • Ethan: early team member and master of the s95 telos
    • Graham: Tester and all around great guy
    • Supermal steel: the testing machine himself first to flash every rom lol
    • Richard: my dutch main man and all around good guy
    • Marcus B: another great tester
    • and all the others from TS Team Zombie
    Like the rom? why not buy me a beer or a coffee? Ive been going through coffee like mad lately lol
    Donations link click here
    Downloads:
    ZOMBIEROM R2
    rebased zombierom with stock tweaked kernel. new kernel incoming in the next week or so when i get new tablet pc thanks everybody
    install instructions:
    • USB burning tool
    FIRST BOOT TAKES ABOUT 6 OR SO MINUTES
    FIRST TIME FLASHING ERASE ALL YOU WILL LOSE DATA SO BACKUP
    AS USUAL USE AT YOUR OWN RISK
    Screenshots:
    Click image for larger version  Name:	Screenshot_20170724-172750.png Views:	1 Size:	83.0 KB ID:	658402
    Click image for larger version  Name:	Screenshot_20170724-172806.png Views:	2 Size:	124.0 KB ID:	658404
    Click image for larger version  Name:	Screenshot_20170724-172904.png Views:	1 Size:	263.1 KB ID:	658406Click image for larger version  Name:	Screenshot_20170724-172941.png Views:	1 Size:	336.4 KB ID:	658407Click image for larger version  Name:	Screenshot_20170724-182148.png Views:	1 Size:	184.3 KB ID:	658408
    Click image for larger version  Name:	Screenshot_20170724-172827.png Views:	1 Size:	120.5 KB ID:	658405
    HOPE YOU ALL LIKE IT
    REPORT BUGS AS FOUND THANKS
    Zombiej79
    Multi-window mode:
    To enable multi window mode edit build prop change user to userdebug reboot.
    Go into developer options scroll down and enable multi window mode.
    In recent apps click the box beside the x and set windows up as needed.
    Split screen works good quad screen mode gets a bit iffy
    Click image for larger version  Name:	DSC_1227.JPG Views:	1 Size:	66.2 KB ID:	658676
    Handy feature to use. For sure
    reserved for update details
    Zombie Rom r2:
    • Fix HD pass through
    • More zombie audio engine tweaks
    • New undead kernel tweaks
    • More controller support
    • Dolby atmos (been working on for some time)
    • Reskin of hphlauncher taps pictures and changing one tab to retro games
      good work
        Mostly thanks to you man you got me going the right way
          Found one bug in kodi 17 don't check dts HD capable reciever just produces high pitch noise looking into fix for r2
            Testing... Thnks for release
              Awesome thanks for testing let me know what you think will have r2 in a week or so so any reports will help improve
                I got this error when use the burning tool
                  OK try loading the img hit start then plug the box in while holding reset button. Let me know if that fixes it
                    Will make flashable zip asap for rom
                      Fixed flashing last Beelink Rom and after flash you rom.
                      The rom comes with 2 launchers, i liked tv launcher, but some buttons like Wifi not working. And TV launcher could have one Games Section for actual games and retro games.
                      The wallpapers im using bing today.
                      Do not comes with FTMC ): or Chrome but is easily to install from app store.
                      Tonight i gonna test some games with Xbox gamepad.
                      The rom is stable and temperature it's 65c below
                      awesome rom, great job and tnks.
                        Will add ftmc and chrome to next build, Yeah I wanna make the wifi on launcher work I'm not the best at modding apks lol but will try and figure it out thanks for the feed back glad you enjoy let me know how the games and everything run thanks again
                        Will
                          Zombiej79
                          Fantastic Job, look at some tricks with Xbox 360 gamepad tested with your TV Launcher.
                          Pressing Button Back for 2 seconds hide/unhide action bar (GREAT!!!)
                          On Web navigation L2 (zoom out) R2 (zoom in)
                          The X360 controller works great on any android TV apps
                          Works nice on the most apps, (im downloading more games and apps now)
                          The controller not work on Google Play
                          Other thing is the virtual keyboard, when i connected my physical dell Keyboard, the virtual keyboard won't hide.
                            Originally posted by natao2008 View Post
                            Zombiej79
                            That's awesome I didnt know the controller would do all that. Awesome find for sure.
                            Im pretty happy with first release. Ppspp and ps1 games with some tweaking to settings the games run pretty great and clean up good. I'm using fpse for ps1 and works great so far. Snes and older systems run great too. Seems to be iffy with OpenGL on fpse will have to do some digging
                            will look into the keyboard not hiding thanks again for the report keep the info coming and I will try and make the rom better and better have some new audio stuff for next version to tweak stock pcm audio better surround sound separation and a few other tweaks
                            Thanks again for testing really glad it's working out so well
                              Interesting Boot and Intro.....Death becomes you ;-)
                              Looks Like an SC Rom (nearly)
                              WiFi on Tronsmart s96 not working
                              Will not switch on in Network settings, will in more settings but not detection.
                              BT Works and Ethernet ok...
                              S96 remote does not work
                              One from Beelink does.
                              Not to bad at all
