How to install recovery on tablet Clust MPX4C97 ?
    Hi muzoka ,
    once more , after PM , maybe, if this Tablet has the same Specs , CPU/GPU/SIZE/WIFICHIP u can try ,
    but always make sure that you have all Files to restore to stock , but if i were u i shall use my Tablet
    like it is / debloat/modify and enjoy .
    Always backup with TB and if you not want to download all Game data new of course the on the internal
    SDCard located Android/data/obb Folder must be copied to your external SDCard too . SDCard out while
    flashing is better .
    I hope it runs well , good luck
    gefattern
      Difficult to say for sure that it would work, or work fully but you could always go for it and see,
      Just make sure that you have all the necessary tools and firmware to go back to stock in case of disaster or disappointment though.
      You could also always post on that particular thread to see what those particular users think.
      -I thank you for all these details and recommendations
