MXQ PRO 4K
MXQ PRO 4K
I've got OTT TV BOX MXQ PRO 4K android 5.1 it has 1gb ram and 8gb rom. It's board is S905Q_V1.0. It's wifi device is REALTEK 8188 ETV. It's flash memomry is Sandisk P545105231. I've tried a lot of roms on different computers, with different os and different usb, but I'm getting an error at 8% 0x30402004]UBOOT/Partition boot/Initialize partition/Error result. any ideas will be apreciated.
Tags: None
Hi georgesurgeon
I've seen this error mentioned before with a variety of suggestions, which seem to indicate (although not necessarily always the case) that using an incorrect firmware can bring up this error.
I wonder if you might consider the Burn Card Method that uses an SD card instead of cable and burning tool.
I use it all the time as one of my boxes doesn't have a functioning OTG port.
I drafted up some generic instructions here.
http://freaktab.com/forum/tv-player-support/beelink-aa/beelink-android-tv-box/gt1/firmware-roms-tools-cg/611261-rom-beelink-gt1-alfawise-s92-scv10?p=627126#post627126
Just be aware that if you do use the wrong firmware then you may soft brick your box.
Here are photoes http://imgur.com/a/H0vPu
Here is log
[20:27:10 446][HUB7-4][Inf]-------------Download meson1.dtb-----------
[20:27:10 446][HUB7-4][Inf]--0-7-0-16
[20:27:10 477][HUB7-4][Inf]-- download mem dtb normal 32690
[20:27:10 477][HUB7-4][Inf]--Send download command success
[20:27:10 492][HUB7-4][Inf]--Read command status success
[20:27:10 508][HUB7-4][Inf]--Transfer complete
[20:27:10 508][HUB7-4][Inf]--Send download get_status command succeed
[20:27:10 508][HUB7-4][Inf]--get_status success
[20:27:11 023][HUB7-4][Inf]-------------ERASE FLASH-----------
[20:27:11 023][HUB7-4][Inf]--disk_initial 4
[20:27:11 023][HUB7-4][Inf]--Send command success
[20:27:22 249][HUB7-4][Inf]--Read command status success
[20:27:22 249][HUB7-4][Inf]-------------Download boot.PARTITION-----------
[20:27:22 249][HUB7-4][Inf]--0-7-0-16
[20:27:22 249][HUB7-4][Inf]--download store boot normal 10029056
[20:27:22 249][HUB7-4][Inf]--Send download command success
[20:27:22 468][HUB7-4][Err]--failed:
[20:27:22 514][HUB7-4][Err]--[0x30402004]UBOOT/Partition boot/Initialize partition/Error result
[20:27:22 514][HUB7-4][Inf]--Close device handle 0x0000054c
[20:27:27 382][Global][War]--User click stop button
[20:27:27 382][Global][Inf]--Enable burning 0
Here are the steps through which I fixed my bricked MXQ PRO S905 box. Just follow these steps and your box will be fixed. The reason why we get this error because the flash chip does not get enough power from the USB port , result UBOOT errors and other firmware errors.
1) Open the burning tool software
2) Load the IMG file
3) Select Full erase option
4) Press Start Button
5) Now connect power adapter to your MXQ Box (Most Important step
6) Now Connect USB Cable into your MXQ Box USB PORT No.4 ( which is near the AV and SPDIF connector side)
7) Now Connect the USB cable into your computer's USB port.
8) If there's any error occur disconnect the cable and repeat the step from 5-7
I hope and wish this method will unbrick your MXQ box life back.
Regards
HaseebLast edited by haseebali; 09 August 2017, 13:47.
Originally posted by haseebali View PostHere are the steps through which I fixed my bricked MXQ PRO S905 box. Just follow these steps and your box will be fixed. The reason why we get this error because the flash chip does not get enough power from the USB port , result UBOOT errors and other firmware errors.
Regards
Haseeb
Hi georgesurgeon ,
you can try this :
http://chinagadgetsreviews.blogspot....c-devices.html
but you need the Stock Firmware i think .
good luck
gefattern
There are currently 4516 users online. 3 members and 4513 guests.
