Hi Guys and Girls,This time the review is for the new Cool Blue Beelink AP34 Ultimate from the guys over at beelink.
The Beelink AP34 Ultimate Supports Windows 10 with the latest Intel Apollo Processor N3450 CPUs (2M Cache, up to 2.2GHz) CPU and Intel HD Graphics 500
Cool Blue Metal Case
Intel Celeron N3450 quad core Apollo Lake processor 1.10 GHz to 2.20 GHz
Authorised Windows 10
Intel HD 500 graphics
System Memory 8 GB DDR3
Storage 64 GB eMMC flash, SD card slot
M.2 SSD slot up to 320 GB
Video Output HDMI 1.4
Audio – 3.5mm headphone jack
Gigabit Ethernet, dual band 802.11 b/g/n/ac Wi-Fi, & Bluetooth 4.0
USB 3x USB 3.0 host ports
Misc Power button and LED, reset pinhole
Power Supply 12V/2A
Specification (From webpage)
Beelink AP34 Ultimate Supports Windows 10 MINI PC and is equipped with the latest Intel CPUs Apollo Lake N3450 Processor (2M Cache, up to 2.2 GHz) CPU and Intel HD Graphics 500, CPU execution speed 50% faster than X5-Z8350, Stand up to 4K for ultra high definition video viewing.
WiFi normal speed 3X, Built-in WiFi 802.11 ac dual-band 2.4G / 5.8G Gigabit Ethernet 1000Mb / s Maximum theoretical downward speed, a variety of options, faster transmission and download.
8GB DDR3 RAM + 57.5GB windows (C : ) + 128G Max Expanded Capacity + DIY SSD, download your favorite programs and movies with smooth and responsive navigation and applications that start quickly. (SD card is not included).
AP34 The MINI PC adopts the advanced USB 3.0 interface, up to 5Gbps, no interruption in the transmission process. Low power BT4.0 Can be attached to handle, headphones, speakers, 10M Transfer distance.
Beelink AP34 Ultimate Mini PC not only has the metal frame, aluminum but also the best cooling mode as it has an aluminum heat sink in a large area so there is no noise. VESA mount design, which is more comfortable and easy to use.
Some internal photos
The impressive heat sink
The under side of the PCB
The top of the PCB once the heat sink was removed (What a job that was to remove the screws was in so tight i had to drill the tops of the screws to remove the heat sink)
The WIFI antenna connection has 2 removable connections that go to the antenna
The DIY M.2SSD slot
The AP34 ultimate use's the same motherboard as Beelink M1 & im told the only differences is that M1 has VGA and AP34 doesn't.So that will be why you will see Beelink M1 on some of the test results and it is also printed on the PCB.
Some photo's of the AP 34 ultimate
On the front of the box is just the power led
On the rear is the power button,12vDC input,1xUSB3,HDMI,RJ45,3.5MM headphone jack and the reset button.
On the right hand side is another 2 USB3 ports,Full sized SD card slot and some vents
On the left hand side is the WIFI antenna and more vents
On the under side is the 4 rubber feet plus more vents
IMO a metal case is a big help with cooling & love the cool blue on this AP34 Ultimate
Right lets boot this beast up see what we have.
Set up
On the first boot of the AP34 Ultimate Took me to the windows setup, language product key etc etc (No need to enter a windows key here) just skip it for now then you will find it gets fully activated after the setup is compleat.I then got notified that there was a windows update (4GB) so i let that run, That Took over 2 hours to update and now i have the latest Windows Version 1703 Build 15063.413.
Device
My AP34 Ultimate is now showing around 40GB of free space in windows after all the latest updates.
A quick video look at the AP34 Ultimate
The Beelink AP34 Ultimate is a all metal square box with ventilation holes, Also a extra large aluminum heat sink on top of the PCB, Giving it a good chance to keep the unit cool and i can say it works very well indeed
What works
64GB & 128GB sd works
128GB USB Stick
Samsung 1TB unpowered HD works
Tronsmart Mars G01 Gamepad works
Logitech c270 webcam works
The boot time on the AP34 Ultimate is around 30 seconds & that takes you straight to the main windows screen where your ready to go.The AP34 Ultimate has more than enough ventilation holes & with all the testing iv done the device has only ever got warm never what i would call hot.I think this is down to the nice sized heat sink thats fitted to the PCB.
Some tech stuff
Crystal Disk
Aida64
Aida cache & memory benchmark
Aida gpu benchmark
AIDA stability test
AIDA stability test stats
Double Driver Back up
Bios back up
https://mega.nz/#!pKZQFQRa!13sF87GRV...OKSd4ib61fZgV0
Unboxing Video
1 x Beelink AP34 Ultimate Mini PC
1 x Power adaptor
1 x instruction manual
2 x HDMI Cable (1 short,1 long)
1 x Vesa mount to mount onto TV
