So I decided to try and make everything fit into a small casing with only 2 wires out... an electric cord and HDMI cable... that's it everything else had to be inside the case, just like a DVD player.
So I went shopping on the net, for a power supply that would be able to power everything. A heat sink for the CPU (inspired by some threads on this forum) so I could run 1080p kernel and eventually overclock that MK908 to 1.8Ghz like the big brother the T428. Then I stared building...
The following are some pictures of the process. Enjoy!
1-The base of the case with access to 3 USB externally and 1 Ethernet RJ45. The HDMI cable is also fixed with the power plug and on/off switch.
2- Power supply (5 volts, 7 amps) is installed with the connection to the on/off switch. I also glued 16 pins connector to provide 5 volts to all the components.
3- The top cover will need cooling so I mounted 2x40mm brushless fan in the back and made and opening in the top for the hot air to exit.
4-To make sure the 5volts power supply is working fine when the case is closed, I mounted a 3 volts LED in the front of the case.
5- Since everything will be in a close case and I want to use the 1080p kernel with eventually some overclocking, I went a bit overboard with the heat sink. Attached to the MK908 is a custom plug I made to connect the power to my 16 pins connectors.
6- Now my MK908 is securely attached at the bottom of my case with power attached.
7- This is an old 100Gigs hard drive with a USB hub, both with custom plugs to get voltage from the 16 pins connector. On the hard drive, I had to solder the USB directly to the board otherwise it would not fit. Also attached to USB hub is the dongle for my RC11 Air mouse remote control.
8- This is how it looks with the hard drive mounted and all the power attached to the 16 pins connector.
9- Another view with all the components mounted.
10- Before closing the case I attached the 2x40mm brushless fan to the 16 pin connectors.
11- This is the top view, where you see the opening for the hot air to exit. We also see the side mounted on/off switch.
12- Back view, with only 2 wires hanging out of the unit (power cord and HDMI cable). We also see the Ethernet RJ45 plug. But in my case the WIFI connection is very good and this Ethernet plug is only for backup.
13- The other side view with the 3 USB plug. Where I can connect a mouse, keyboard or another external hard drive. But since inside the casing I have the RC11 dongle, I don't need those USB for now.
I tested the unit with a 1080p movie without any issue and nice warm air was exiting from the top of the unit. Everything seems very stable for the moment. Now I need to decide which ROM to install.
I hope you enjoy the pics as much as I enjoyed building this unit. If you needs more details or part number, just ask.
